will a 245/35/19 work on 19x9.5 +22 wheel for s14 rear ?
will it be crazy stretched on a s14 rear ? rears have 3.5 inch lip and fronts are 19x8.5 +15 and possibly a 225/40/19 with 1.5 lip,
currently running 245/35 front and 285/30 rear
You might want to do 245/40 just to have that extra sidewall when they mount the tire.
I tried mounting a 19x9.5 +25 on my 14 before just to see how it would look. Turns out I need a 15mm spacer in the rear and at least 10-15mm spacer in the front plus rolling the fenders and running 3-4 negative camber. The front will be hard to fit due to limitations, they never really meant to have anything bigger than 18" on the 14 technically. But people still do it.
Yeah, 19's on a Z33 is what they were built for, but on a 240, its really hard to do. I tried on my 14, you will need 10-15mm spacer in the front (your choice, but 10 would be fine) 10mm I think is fine in the rear.
i ran a 225 on a 9 and 255 on a 10 which is a similar ratio to what you are talking about and it definitely was not a crazy stretch. Its the car in my sig. 19s are a bit large and certainly not ideal, but you can run them.
With those offsets on a 19, the out lip of the wheel is going to be pushing the limits of the stock body. When you run something like a 17 with a somewhat stretched tire, you have more room to play with on aggressive offsets
