sr20det vacuum hoses?,and smoky manifold
Well , I got my SR to run but its not smooth .I was wondering if anyone has a pic of how its supposed to go,and also i think i might have one of the vacuum hoses hooked up to the waste gate actuater and i was curious to know if i have it connected to the right line because it smokes a lot! BTW i have it connnected to the small little pipe coming out under the throttle body.
the small line under the throttle body should get capped off. it doesn't get used. the small hose on top of the throttle body goes to you fuel press. regulator. T into this line if you are using a boost controller or gauge. the big line on top goes to your blow off valve(if you are using one, and you should). on my car i have a greddy profec b boost cont. so it is t'd into the big line on top and then another line runs from the controller to my wastegate actuator.thats the way my car is set up and everything works. (the is probably caused by something else.)
Treyz
02-21-2007 03:54 PM
nolimitmr2
08-01-2004 09:41 PM
