sr20det crank pulley removal
Old 11-03-2006 | 08:39 PM
bs280's Avatar
Does anyone know where i can get a crank pulley removal tool for the sr20det or can you give me some advice on removing the crank pulley. thanks
Old 11-03-2006 | 11:58 PM
just go to an auto parts store and rent out a pulley remover, it should have three arms on it and go at it...
Old 11-04-2006 | 04:01 PM
bs280's Avatar
how would that work if there are no holes for the puller to screw into?
Old 11-05-2006 | 10:52 PM
Darkvillin's Avatar
i just used a mallot on my ka. but the engine was out of the car. it was still a biotch to get off tho.
Old 11-06-2006 | 10:30 AM
I just did this about 10 minutes ago, I purchased a 2 jaw 5" gear puller from ACE hardware for $6.49.
I made the cranshaft bolt loose so I was able to adjust it, so there was play. Then, apply the puller with the center on the "grooved" area of the Pulley bolt and slowly tighten the puller.
It should start to walk the Crank Pulley off. You might have to readjust the bolt/pulley to get it to fully come off. Should take about 5minutes.
positron
SR
01-06-2008 07:45 PM
s14Drifter
09-28-2007 03:20 PM
Purple240
08-01-2006 07:46 AM
thekage
05-09-2005 11:43 PM
Casey240
03-24-2004 09:04 AM
