Selecting a turbo/reading compressor maps
Ok. I have spent hours reading on this. I am looking at a Garrett GT25/40R turbo for my 95 KA24DE motor. I cannot figure out how to read compressor maps for the life of me using what little info I did find. I think I need the flow rate of the KA in order to make the maps more relevant. Although I am not new to the world of turbos (mostly experience with bolt-on kits), I am new to how to match a turbo up to a car based on the flow and efficiency which is seen on the compressor map. I am trying to put together a kit for my car, and want the best possible combination of parts/fastest spool time. My goal in the end is to run anywhere from 350-450 rwhp. Here is a link to the compressor map for that turbo.
http://www.atpturbo.com/root/maps/gt2540r.htm
Here is the link to the turbine map. ( what do I need to know about this map?)
http://www.atpturbo.com/root/maps/gt28rsturbine.htm
Also, from what I gathered, a lower A/R will produce a quicker spool-up, but a higher A/R will give more top end power, but more lag. Is this correct. If so, I would be looking at the .64 A/R for this turbo. It is now 3:30am, and I'm not sure if the post quite makes sense, but I am at a loss after about 4 hours of research on this. It is killing me. Any help or other information that I might need would be appreciated.
-Nate
-Nate
