my stock sr20det is running 11.47 boost???
It is running this and i dont see anything that is after market???
Maybe Actuator???
Any ideas and it sounds as if im getting over boost.... Like turbo is past what it can handle and dumps the extra out after full throttle.. ITs hella fast but i dont want to go booom!!!
How do i lower boost??
Boost controller? OR find out why its boosting high and lower that some how?
I run 100 octane and 91 mixed 50% = 95... wich is minimum a sr20 should run no mater what people tell you.. THe ECU fixs pining but you should run at least 95... RON....
HELP!!!
thanks..
jeff
Maybe Actuator???
HELP!!!
thanks..
jeff
Re: my stock sr20det is running 11.47 boost???
RealY? I have been trying to find that research on Ron and AKI.. Were did you find that? ANd running @12psi you better hope you run 95.5 octane here in the US or else youll fk up your motor..
Its not wasting your money its wasting your motor...
I run 100 ocatne AV GAS!!
jeff
jeff
I looked up the AKI and RON conversion online years ago when I was thinking of putting a Silvertop 4AGE in a AE102. That engine requires 100 RON which equals out to about 93-94 AKI. I always just put 93 in my SR, was running bout 11 psi on a stock side mount for almost 2 years with no problems, dyno proven, car ran perfect with that boost/octane/setup.
Thats good info thanks. I have been reading a lot about lowering boost and getting more cold air into turbo. I know it works because i have seen it. Im going to look into that. It would be nice to run 5psi and still run like 12 psi...
AV gas is the big secrete though. It has little lead that protects the valves, rods, and pistons and its 100 and its safe i have ran it...IT is almost the same price as 91 right now... $3.79 wich is up it should be under $3.00
thanks
jeff
thanks
jeff
I'm kinda interested in finding out what the effects would be on internals, but I'm never gonna use it (My car's mpg's are ****ty enough) and I'm lazy so....
Originally posted by bZeRk187
Do you have a 3" exhaust? It will raise stock boost to around 1Opsi.
And going with what everyone else says, I would check your actuator. Your motor and turbo will be alright handling that kind of boost, so go with it and make sure you keep up on routine maintenance.
jeff
jeff
93-94 octane is suffecient enough for 18-20 psi on a properly tuned SR...some companies like Jim Wolf, also offer their programs in a CA style (for those with 91 octane) and another program for the rest of us.
For Sale - Wheels / Tires
11-02-2007 08:09 PM
