My Ka24e turbo project
I have been talking with TonysS13 and others working on my SOHC ka-t project. OK so after alot of research I think I have finished my Turbo list.
Manifold Realnissan $450
Turbo T3-T04 from www.turborepair.com (2 year warrenty) $450
HKS Super AFR (research made it sound better) $340
Turbo Timer Type-0 Silver HKS $80
Ca18det or Sr20det injectors $120
Fuel pump (suggestions who?) $150
Autometer guages, boost/A/f $80
custom exhaust $300
Waste Gate HKS $350
BOV HKS $220
FMIC $700
Oil Lines $40
vaccum lines/misc lines $20
Boost Controler $100
Did I forget anything???
Let see that is $3400. I will be doing the install my self so I will be ok. I would just like to know the best place for MAF??? and If I missed anything on my list???
P.S. I'm a huge HKS fan so that is where alot of my products come from.
custom exhaust $300
Waste Gate HKS $350
BOV HKS $220
FMIC $700
Oil Lines $40
I think the Walbro in tank fuel pump is the one most SR swap guys go for so it should handle your turbo duties.
I don't know much about the MAF swap but I have heard of some swaps. I will look around on my computer.
I don't really know anyone except Tony that has done the sohc turbo so I don't really think you will have many people to get tride and true advice from.
You will get help anyway. PM me if you need any more info.
Thanks StanBo. I am just using my stock MAF and I have decided that I will mount it after the BOV so I don't confuse the computer when the BOV goes. The more and more I search the more I think that I have it right except i may need an igination upgrade. I also might need a fuel pressure regulator, but with the HKS Super AFR I will adjust it manually so I don't think I will. But if anyone has any suggestion please post. When I get done it will be a killer at about 8psi.
I will be if I pass this test tomorrow.
I would think that you will want a mechanical FPR in line as a fallback for the HKS.
Originally posted by StanBo
I don't know much about the AFR because I am not a boost junkie yet.
Originally posted by boro240
what about internals? how much do you plan to boost?
Sounds like a nice setup. You shouldn't be disappointed with the results either. The T3/T4 is a good choice as well because it can hold plenty of boost and shouldn't have a problems spooling up at all. I'm just wondering why you didn't want to go with greddy on some of your stuff.
I would get a fallback except that I an going to have a air/fuel gauge so if my HKS AFR fails then I will know right way when my gauge goes to lean.
If you are going to run a gauge as a failsafe please hook up an audible and visual sensor to it. One that will lightup and buzz/ring if the AFR fails and your car decides to dip LEAN.
The real reason I'm not going with greddy is that I think HKS is better. I have never hear of anyones car blowing because of a failure by an HKS part. Also Greddy's parts are more money. After saying I will have a HKS waste gate I think i will change that to a tial 35mm waste gate (it is about $120 cheaper).
just outta curiosity, why did you choose the t3/t4? is that the best one? also, are you serious that the turbo is only $4-- dollars?!? the others i have been looking at are like 2 grand on average.
http://shop.store.yahoo.com/cheapturbo/index.html
They will sell a brand new GARRETT T3/TO4E for 550. The turbo i talk about before was rebuilt. But this one is brand new. I might even get a GARRETT T3/60-1 for 650 that turbo is huge.
