Garrett GT-RS
Old 11-17-2003 | 10:51 PM
asalatt's Avatar
So, how did it go?
Old 11-18-2003 | 08:01 AM
Turboed240's Avatar
Well, I finally heard back from him. He wanted me to get a list of how many people would be interested and then he could give me an accurate quote on pricing soooooo....let the list begin. Please provide me with an email so that I can just contact the people interested.
1. Turboed240
Old 11-18-2003 | 03:16 PM
asalatt's Avatar
2. asalatt. asalatt3@hotmail.com.
Who is your contact at Precision Turbo and how to get a hold on him? Do they have a website?
Old 11-18-2003 | 03:22 PM
asalatt's Avatar
I think you should start a new post for the group buy. BTW how soon do we get the turbos? do they have them in stock?
Old 11-20-2003 | 10:34 AM
Turboed240's Avatar
Okay...so I got some more info on this turbo. The turbo is a Garret T28. T3 wheel trim. Compressor Specs: The inducer diameter is 1.83"/46.5mm. Exducer diameter 2.37"/60mm. TB03 housing. 448CFM max flow. T25 wheel with a 62 trim. Turbine Specs: Exducer Diameter is 1.64"/41.7mm. Inducer Diameter is 2.09"/53mm. T25 housing and flange. Dual ball bearing w/internal wastegate. Max efficiency @ 78% for 2PR at 29psi.
Bottom line is, will this bolt on? If so, I will get together a group buy.
Old 09-09-2004 | 05:49 PM
b2stud's Avatar
so its not a gt28rs. unless its a stock t25 or t28 its not a direct bolt on. it may fit the manifold but it probably wont fit the turbo outlet and the turbo line treading might be different so unless you have all the tools at your disposal it can be a pain in the ***. If it was a gt28rs i would have been down for a group buy.
Old 09-09-2004 | 06:38 PM
FI AutoSports's Avatar
1.) If you (Turboed240) are a business, do not post up those prices. This causes alot of people claiming that they can get it from somewhere cheaper than they really can't, as it is a special deal. if you are not a business, then you do not have distributor prices, but dealer prices. They guy selling the turbo to you may be a distributor, and is selling them to you under GB status.
2.) If it is a just a Garrett T28, then I think those are excellent prices. But based off the specs you gave, it is not a regular T28, but a GT28R turbo. Dual ball bearing with internal wastegate. And if I were going to spend $700+ on a turbo, I sure would not want one that would only flow up to 300hp. Getting power from a turbo car is easy, unless you get too small of a turbo. That GT28R, according to Precision, pushes 300hp (~260whp), not even enough to get you into the 12's.
If you want to make respectable power, between 300whp and 400whp (notice the difference between whp and hp, whp =power on the ground, hp=power at crank), then I suggest the SC50, 76 trim, .63 A/R, . It will flow up to 450hp.
Or if you want the most common, a Garrett T3/T04E. I have seen them as low as $549, and they flow upwards of 450hp.
ixcocoyxi
04-18-2005 12:23 PM
r0ck3r
11-14-2004 06:33 PM
inthedrift
10-14-2004 12:20 AM
97nissanaltima
06-12-2004 02:07 PM
robinsongtir
07-06-2003 12:03 PM
