blown turbo gasket?
blown turbo gasket?
i can hear a serious exhaust leak comming from my turbo area, and i checked and there is air pouring out from the manifold connection to the turbo. I already got a new gasket from heavy throttle, has anyone had to do this to their SR? any suggestion on the easiest way to drop the turbo?, i also noticed that the side the air is leaking out, there is no nut there.... do u think thr gasket is fine and it just needs a nut? Thanks for any help.
ive taken everything off the turbo because i need to replace the gasket, and the hotpipe is coated in oil...... yea, i talked to my mechanic and said if its not too much then it moight not be anything but i dunno. does anyone else have this problem?
cmcdougle
01-19-2007 05:22 AM
