volk racing gtc
Old 03-05-2005 | 06:15 PM
da9fan's Avatar
volk racing gtc
I own a set of Volk GTC wheels. They are 18*10 +37 and 18*9 +42. The problem is that I drive an S14 and the front wheels hit the suspension. Since they are two piece wheels, I was wondering if I could buy another face that would have a different offset so that I could use the wheels on the front of my car. Please let me know if I can do this. Also, is it possible to convert from a face 1 setup to a face two? I really like how the rears fit cause they are flush and the fender just needs to be rolled a little bit. PLEASE HELP
Thank you
Rovin
Old 03-05-2005 | 08:59 PM
JVD's Avatar
JVD
Just throw some suitable wheel spacers on the front.
JVD.
Old 03-05-2005 | 09:50 PM
ArticDragon's Avatar
You have the wrong offset there buddy. Two guys here will most lkikely flame you for having such high of an offset on an S14. What I recommend you do is either get spacers, or get a different face to attain a much lower offset on both fronts and rears.
Old 03-05-2005 | 10:38 PM
da9fan's Avatar
i didnt know that they sold different faces that would change the offset. Could someone verify this for me and also, what size offset should i run and do I need extended studs for it?
Old 03-05-2005 | 10:52 PM
Catharsis's Avatar
are those 3 peice?
Old 03-05-2005 | 11:40 PM
He said they're two piece.
Old 03-06-2005 | 07:38 AM
da9fan's Avatar
yeah, they are two piece wheels
the rear ones are face 2
and the front ones are face 1
Old 03-06-2005 | 09:10 AM
Catharsis's Avatar
go to www.kodiakracingwheels.com and have them make you some wheel halves that work for your 2 peicee front and get a proper offset
Old 03-06-2005 | 11:28 AM
bleach8484's Avatar
Did you buy those used? those sound like Supra offsets or somethin. I have GTC's face 2 18x9 with a +38 offset, and they hiit up front. Your gonna need a huge spacer and some extended wheel studs more than likely.
Old 03-06-2005 | 11:35 AM
da9fan's Avatar
yeah, they are off a Supra. I got em for a really good price tho, so i couldnt let them go.
Old 03-06-2005 | 09:45 PM
barrigaS14's Avatar
sell them and buy same rims with proper offset.
Old 03-13-2005 | 04:04 PM
da9fan's Avatar
i did some searching and got the wheels to work with 20mm spacers up front and nothin in the rear. Surprisingly, the front doesnt stick out and the back is a little out. I will roll my rear fender to lower it.
My question is however, can I run full coilovers? The front wheel has about a quarter of an inch clearance to the shock body.
As I understand, the perch on the coilover kits sit lower making it come below the tire. I dont know if I will have enough space to do so.
Please let me know as I do not want to buy some and dont work and I really dont want to buy springs.
Old 03-14-2005 | 08:46 AM
barrigaS14's Avatar
so in the front you are running a +20 spacer with a rim of +42 right. and in the rear you are running a +37 no spacer...things to do.
1) no coilovers will not clear front. you need at least +20mm offset all together, or less.
2) throw the +20 spacer on the rear and
3) find a +25 spacer some where for the front.
Old 03-14-2005 | 10:36 AM
da9fan's Avatar
Thanks barrigaS14. How safe is it to run that large of a spacer in the front with extended studs. If there is little danger involved, then I will go and buy new spacers.
Thanks again
Old 03-14-2005 | 10:48 PM
barrigaS14's Avatar
go here...and fast...they just got them in and it takes about 3 months to get again if they sell out.
https://www.optauto.com/index.htm?pa...7&deptid=12539
these bolt to the hub and have new studs in them. i ordered two sets already. you might want to find a 25mm one though. only problem is i don't know who makes them (25mm).
