TW: 13" Rotors, Caliper Brackets
Before I go ahead and make brake caliper brackets to use 13" Cobra rotors with Z32 calipers (Front), I want to know how much interest there would be for this. Basically you would be getting the two brackets and hubcentric rings(or spacers for the lug bolts to keep the rotor centered) and all hardware needed for install. It will allow for the use of the 13" cobra rotors up front with your 300zx 4 piston calipers.
Cobra rotors are 330mm~13" x 28mm
First, this is not the forsale section. Secondly why dont you make a set for yourself and every track event you can think of for 6 months straight. To make sure you design will hold up, before you want to mass produce.
Until you can come back with proof that your **** works. This is closed.
rancidnsx
03-08-2005 11:54 PM
PissonH
08-28-2004 11:45 PM
DRFT240
04-24-2004 12:17 AM
