Someone Help me clear up the camber issue
Old 03-05-2003 | 03:35 PM
jtsarnak's Avatar
Ok, so I'm going to upgrade my suspensions soon, but everything I read says something about an increase in negative camber when lowering the car. So here's my planned setup:
'95 240sx SE
Eibach Prokit Springs
KYB AGX shocks
So when people talk about camber, is it a problem in the front, the rear or all around? Is it adjustable in the front, rear or all around? For the areas which aren't adjustable (or are, but not enough to correct the problem) what is the best way to go towards correcting the problem?
Thanks for any help.
Old 03-06-2003 | 10:17 AM
rudeboy's Avatar
ok brah..
with sportlines you will have a little extra negitive camber.
in the front you can take the best route and get some front camber plates.
and rear eccentric bushings.
that will cure up things for you
Old 03-18-2003 | 07:48 AM
jtsarnak's Avatar
Sorry, I made a mistake in saying "Proline" in my original post when I meant Prokit, the set that drops the car less than the Sportlines. Given that case, does that change my camber situation and anyone's suggestions?
Old 03-18-2003 | 08:45 AM
rudeboy's Avatar
with the prokit you might just use camber bolts in the front and nada in the back
you shold ride pretty flat then
Old 03-18-2003 | 09:48 AM
Catharsis's Avatar
at least you can dial your camber out... mine will be cambered all the time.... as sooon as they get here...
Old 03-18-2003 | 07:07 PM
rudeboy's Avatar
i only have 3 strut towers
onelove240
03-22-2008 08:50 PM
s13silvia123
08-04-2006 06:26 PM
jspaeth
04-02-2006 11:01 PM
redpotatoes
12-22-2005 10:00 AM
NissanPower s14
02-06-2005 01:15 PM
