Slotted Rotors for z32 Calipers?
Old 05-09-2004 | 01:30 PM
KozyNissan's Avatar
I currently have a pair of 1990 NA 300zx calipers and am looking into getting some power slot rotors for them. The OEM rotors are 26mm. The tech guy at power slot says that depending on what month the car was manufactured there are two different bolt patterns.
Before 6/90- 508 PSL & PSR (FRONT)
509 PSL & PSR (REAR)
After 7/90- 552 PSL & PSR (FRONT)
Can anyone please tell me what this means, and which one will fit the application I described? This is really important because it would really suck to try and just guess which one is right for the calipers I have. thanks.
Old 05-09-2004 | 08:12 PM
JeromeS13's Avatar
Well, production date of 7/90 would actually make it a '91. If you have 26mm calipers, you'll need the ones for the production from before 6/90...
And, its not the bolt pattern that is different, its the thickness of the rotors...
Old 05-19-2004 | 07:01 PM
Fireplug's Avatar
Just get a set of Brembo Slotted rotors from HeavyThrottle (www.srswap.com) they're 149.00 and tell them you want them pre-drilled for a 4 lug 240sx. I did it, works great.
Aaron
Old 05-19-2004 | 08:44 PM
Aaron
***Off topic***
Fireplug, your sig is hilarious
BigVinnie
02-17-2008 08:52 AM
boxer
06-10-2005 02:43 PM
Zero_SX
11-30-2004 03:33 PM
jdmsoarer
11-23-2004 06:24 PM
badman70_1
16
03-01-2004 09:02 AM
