s14 front shocks vs s13 front shocks
Old 05-21-2004 | 09:35 AM
irax's Avatar
by what i have seen in pictures the s14 fronts look like they are shorter then s13's is this true ? does any one have a side by side compairison of OEM or KYB's'? if they are shorter that means idealy its a better shock to use for lowerd s13's. just an idea since the coilovers are interchangable for the fronts...
Old 05-21-2004 | 03:56 PM
JeromeS13's Avatar
There shouldn't be any height difference in the two. The main difference is the size bolts that go through the lower section. IIRC, the S13 accepts a 12mm bolt and the S14 accepts a14 mm bolt.
Old 05-22-2004 | 12:01 AM
irax's Avatar
there isnt a size difference?... dam it... lol there goes my idea for short strokes...
Old 05-24-2004 | 01:30 PM
aren't s14/s13 shocks up front basically the same everything (except for the lower bolt hole)? That's what I was told
Old 05-24-2004 | 03:28 PM
JeromeS13's Avatar
Isn't that what I said??
Old 05-24-2004 | 04:34 PM
Well you reffered to "height difference" whereas I was talking about the entire unit
Bernie (NoVA)
11-27-2011 09:03 PM
oceanblue_1128
08-07-2005 12:06 PM
ebanfan
02-09-2005 06:49 PM
Crimson
08-14-2004 01:43 PM
ryan15
01-19-2004 05:15 AM
