S13 Rusted Underbody To Clean?
Old 08-24-2008 | 11:46 PM
aznkipz's Avatar
How can I get my rusted underbody cleaner? I want to get rid of most rust or some?
Old 08-25-2008 | 12:04 AM
cut it out and re-weld..or fiberglass if its not a sturdy area to begin with
its rust man..you cant just wash it away
Old 08-25-2008 | 04:30 PM
Die Trying's Avatar
sandblasting is the only way to remove rust. after you sandblast it you can spray undercoating where you need it. no need to prime the spots where you sandblasted cause the undercoating will seal it up good. you will only need to cut and weld in new pieces if the rust has eaten through
Old 08-25-2008 | 09:21 PM
If it's not that bad you could go to work on it with a wire brush and some Por 15. If it's rusted through, you need to replace metal.
NismoSX
08-23-2008 05:01 AM
bob804796
01-25-2008 03:40 AM
josh240caseysx
06-08-2007 03:18 PM
lstock
06-29-2005 04:51 PM
cybin
09-16-2004 05:26 PM
