QUICK: 16x7+35 or 16x7+29?
well im just getting these rims for my ladies s13, they are watanabes and im getting them because if I get tired of them they always got resale value. I am so confused on this whole offset thingy, I read the sticky on it but I just still dont get it, so what would a -5 offset look like (way to wide). So the lower the offset the more it will stick out?
This is also your
friendhttp://toy4two.home.mindspring.com/offset.html
Type in your current wheel specs and your then your new ones and it will tell you how far the will extend towards the fender and if it will clear your strut housing.
16x7+29 obviously. Both will clear coilovers.
If you have a 16x7+35 though, just put on a 30mm spacer.
I used to run 16x7+8, 16x8+13 Watanabes, perfect offset with spacer (30mm/25mm), nice and flush. As shown here, they're for sale if anyone wants them.
Originally posted by JDMxDrift
you had to use a spacer even with the width being big and the offset low?
i used a 30mm on the front and 25mm on the rear. therefore the resulting offsets were the ones i listed in the other post.
srdsil80
01-03-2005 02:46 PM
avr180sx
04-22-2004 01:31 AM
