pillow mount tension rod noise?
Old 11-17-2005 | 01:05 AM
Carparthookup's Avatar
I have some secchi pillow mount ball joint tension rods that i bought from projectnissan a long time ago
and everytime i step on the brakes, it makes a clunking noise. Im guessing its the pillow mount ball joints
does anyone else have this problem?
Old 11-17-2005 | 01:17 AM
Levi SPL S14's Avatar
well they will wear over time.
just lift the car up and check all the bolts and what not.
Old 11-17-2005 | 11:00 AM
Make sure the tension rods (the threaded section) is tight too. And get off the damn cell phone when you host a car meet ROFL
Old 11-17-2005 | 11:14 AM
ive checked and rechecked, everything is tighten,
could it be the tension rods? or something else?
my front suspension looks decent, only thing i can think of that would make the noise is pillow mounts.
i was trying to get my friend to come that night heh
Old 11-17-2005 | 01:16 PM
Roastem's Avatar
just a guess but make sure your caliper bolts and caliper bracket bolts are tight. if the bottom bolt is loose it will slam back down when you hit the brakes.
Old 11-17-2005 | 01:25 PM
hmmm, I'll try that. thnx
Hamsterball
04-12-2005 11:23 AM
wei240
07-27-2004 10:15 AM
yektik99
07-22-2004 11:06 PM
_MM_
10-24-2003 06:30 PM
S14DRFT
08-13-2003 11:58 PM
