nissan 240sx big brake option ??
i have an 93 240sx abs , no super hisca , stock everything
i want better brakes , i have many questions feel free to clarify anything , is there any ways to install a 300zx 4 piston nissan , maybee something like z32 not the brembo , i looked other topics nothing realy clear , i dont want to make a 5 bolt convertion cause i allready have some 4 bolts mags , so my 17 inchers will clear the bigger rotors , can i profesionaly redrill my 5 bolt rotor off a 300zx tt into a 4 bolt? to fit my 240sx?, if i only install 300zx brakes in front but install a 300zx tt master brake cylinder will it fit bolt on my stock 240sx brake booster? and will the rear brakes brake more ? there are several weird question i seek awnsers , wich i cant find , the full rotor size topic i love , but will the 300zx caliper fit bolt on my 240sx hub adaptor or will it need a braket ? will the hose fiting fit , is there any 4 bolt rotor big enough to endure the beating im about to give it , so to resure
big 4 pot caliper ? wich will fit bolt on my 4 bolt 240sx?
z33/z32 master brake cylinder? bolt on to a 240sx?
discs? wich ones? how big diamiter how thick?
what other options , g20 brakes? 300zx? r32? r43? anything you tried liked or disliked?
If you wanna go four pot, go with the Z32 front brakes. Pretty cheap and basically a direct bolt on.
The fronts are either 280mm x 26mm or 280mm x 26mm.
You would need front calipers, rotors, and Z32 brake lines. You also need to trim, or remove the dust shield. As for keep them 4-lug, you just have to drill out the rotors for the 4 lug set up. From what I have seen, they fit under most stock S13/S14 rims.
The upgraded MC would either be an auto S13 MC, if you have a stick, or the Z32 MC, again direct bolt ons. I hear you should change the brake booster to a bigger unit for easier pedal travel.
The other option is the J30 fronts brakes. They are a dual piston set up, as opposed to a 4 pot. The rotors are smaller than the Z32 set up, but still bigger the stock set up. And they are also a bolt on mod. Hope that helps. If not, refer to one of the stickeys above.
I have never seen the 300zx rotors bolted with factory wheels but as said above, the j30 rotors and calipers are a direct bolt on if you get the rotors redrilled to 4-lug.
Just check around first and find a shop that will do this. I have come across a lot of fab shops that refuse to redrill rotors.
i saw on ebay z32 300mm rotors for the 4 lugs 240sx , i have an auto s13 , i might as well just keep the master cylinder , and install z32 300zx twin turbo nissan 4 pot calipers , , are the caliipers bolt on to my hub asembly without any adaptors? , with the size of the rotor , my original is smaller check it out on ebay , its sold as 300zx conversion discs. sold in either 4 llug or 5 lug upon request., and are zinc coated and comes with braided brake lines? is this a good item?
positron
10-29-2006 12:54 AM
RafStar
10-07-2005 10:37 PM
NightXCZ77
02-01-2003 09:40 PM
