Lower Rear Tie Bars for S13?
Old 10-16-2002 | 08:04 AM
Rynxprs's Avatar
Anyone make them for the 89-94 model years?
Old 10-16-2002 | 12:15 PM
Import Fanatix's Avatar
I know OBX makes it. its like $100. www.Enjukuracing.com
Old 10-16-2002 | 01:09 PM
Justin.b's Avatar
Pass - you don't need them.
Honda's need them because they have weak *** rear suspension mounts and no rear subframes. The 240 has a significant sub frame that's not likely to benefit much from an OBX brace.
-Justin
www.saltgod.org
Old 10-16-2002 | 02:24 PM
all for style, na mean, everything counts for points at the show if its not functional.
Old 10-16-2002 | 02:34 PM
Justin.b's Avatar
Are you talking about a rear strut bar or rear lower tie bar?
Rear strut bars are available and will add some rigidity - especially in hatches.
Rear lower tie bars correct the uniquely honda problem of flexibly floor pan between the suspension mounts, and are not readily visible.
-Justin
www.saltgod.org
Old 10-24-2002 | 06:30 PM
Well I don't know if its a NY thing, but they can be seen from almost any angle when looking at a Honda from the Back, so for me that is readily available and I know for a Fact that it can be seen at some distance.
They do help out Hondas and as previously said don't know how much it would help out our 240s.
Old 10-24-2002 | 10:18 PM
Justin.b's Avatar
Nope.
You can get a rear strut tower brace, but real lower tie bars are specifically designed to beef up the flexible rear suspension points of some FWD cars.
The 240 has a stot rear subframe that the suspension mounts to, it also has some things like a driveshaft and differential that would prevent you from getting a straight shot across the suspension mounting points.
-Justin
www.saltgod.org
Old 10-25-2002 | 08:07 AM
Well this is how it looks if anyone still is interested.
Old 10-25-2002 | 08:42 AM
Justin.b's Avatar
Who makes that?
What is it supposed to accomplish?
-Justin
Old 10-29-2002 | 12:01 PM
Catharsis's Avatar
for some good parts at a good price for rebuilding your suspension try www.pdm-racing.com
Old 10-29-2002 | 12:07 PM
Who makes that?
-Justin
Made by OBX
Old 10-29-2002 | 08:15 PM
Justin.b's Avatar
If you're seeing the lower rear braces on slammed Hondas, you're car may be alittle too low.
-Justin
Bumnah
04-06-2009 08:38 PM
ryderg
10-19-2006 07:14 AM
racesynergy
04-05-2006 10:33 AM
RealDS13
05-24-2005 05:53 PM
240SXDrifter
01-08-2003 01:40 AM
