kyb and tokico
kyb and tokico
are tokico shocks any good ? the non ajustable ones that are blue ? and how do they compare to kyb ajustables... i just cant see using the ajustments on the kyb shocks much so i would like to know if the tokico shocks are good enough for autox etc or any other shock recomendations would be good thanks
The Tokicos are fine if you're using the stock springs. They will wear out very quickly and not perform very well before wearing out if you're running them with lowering springs. That's what I've heard from someone who has done it - I haven't used them personally.
If you're going to drop the car, the AGX's are worth it even if you don't plan on using the adjustability.
-Justin
-Justin
I'm not sure about struts for 240's as I haven't personally seen any, but AGX's aren't the best for lowered cars. They have a long piston which equals short travel on a lowered car. The Tokico Illuminas are about an inch shorter which provide you with more travel. I know a lot of guys who put the Illuminas(5 ways) up front, and AGX's(8 ways) in the back. It tends to yield a pretty good setup as far as adjustability and ride go. If you plan on AutoXing then adjustables would be beneficial. Changing the settings is pretty easy...the rears you just turn a **** on the tube, and the fronts you adjust at the top with a small screwdriver. That way you can have a soft, supple ride for the street, and stiffen them up for track use.
jbask
03-15-2005 04:50 PM
240wongsta
03-10-2005 03:51 AM
japan-air
02-21-2005 09:38 PM
<cartman>
07-02-2004 06:31 PM
