KYB gr2 shocks and coilovers
Ground Control.
check the application guide on their website. i think there's three different systems available, one for stock shocks, one for gr2's and one for agx's. Not sure, check their website. Of course you can't mix them up, each system was developed for each kind of shock.
but then again GC's are only ride height adjustable...
and i started a thread about gr2's a little earlier
http://www.club240.com/forums/showth...&threadid=8113
Re: KYB gr2 shocks and coilovers
Originally posted by bonomo
I need to know if there is a gr2 kyb shock that is made for a coilover and to fit a 92 240.if so where do i get them
and which coilovers do u recomend to use for street/ drag.
If you're into street/drag, you might want to go with AGX's over GR-2's. GR-2's were designed as a mild upgrade from stock shocks. If you go lower than 1.5" the ride will suffer.
so i should get kyb agx's i need to lower it like 3.5 inches
are drop zone a good coilover.
...so you say you NEED to lower your car 3.5"? May I ask why so low? I thought this was a daily driver / drag car?
If you want to go anywhere near the low, KYB's and springs/coilovers won't work. You might need Teins, but still - the 3.5" part doesn't make sense. You might as well go airbag and forget the drag all together if you want to go that low.
And Drop Zone coilovers aren't recommended. Basically they suck. Technically, what do you expect from sub-$100.00 coilovers?
240Drifts
03-15-2006 09:40 PM
iceperformance
10-08-2002 08:23 AM
