Important: Need Response ASAP
Old 09-09-2004 | 12:14 AM
SlyGrin's Avatar
Exclamation Important: Need Response ASAP
A little over a week ago I ran into a curb and I broke the steering rack in half on the passenger side (along with the lower control arm and tie rod ends). I have been calling around but a steering rack (my biggest worry) is $1314 brand new from a nissan dealership. I also have an s13 that I was selling, but if I can use the steering rack from that (which is my question that I have been wondering all along), then I will prob just use that and replace it later. So what this all boils down to is:
IS AN S13 STEERING RACK INTERCHANGEABLE WITH THE S14 STEERING RACK?!?
Thanks,
Sly
Old 09-09-2004 | 09:07 AM
juztinvez's Avatar
everything i've read leads me to believe they can be swaped. i know s13's can use s14 tie rods, the energy suspensiong bushings work for the 3z s13 and s14 so i assume they all mount to the engine crossmember the same way and that leaves just the column knuckle whitch should be the same and if not i think you can swap it off your s14 rack if it still good. good luck. i make no garauntees but i'd do it if it was my car.
erebunialtima
04-07-2004 08:02 PM
auto240
12-11-2003 08:38 AM
CALI KaRtEr
08-29-2003 10:45 PM
D1DriftS15
08-17-2003 08:44 PM
rudeboy
11-18-2002 01:44 PM
