Help rear brake ona a S14 seized
my friend has siezed his rear brakes 3 times in the past 6 monthson his 95 S14 SE. Fist time he fixed it with new Fluid, Calipers, Pads, Rotors and emergency brake cable.
Then it happened Again he took it to a shop and they fixed the exact some parts.
Now it happened AGAIN
Any Advise on what to do about it We r lost
Re: Help rear brake ona a S14 seized
Then froze them again.
I changed my brake master cylinder. The 240sx has an integrated proportioning valve / master cylinder. I know that my rear piston failed and did not pull back when pressure was released of the pedal.
Changing the brake master cylinder was my solution. Now I have too many rear calipers in my house and rotors that are beat to ****. They are all being given to friends that need them and I am moving on to a whole new system.
Good luck.
Enlefo
09-08-2007 07:41 PM
nissans13
08-23-2006 03:54 PM
