Hardly any brake pedal?
What would cause the brake pedal to be very soft, and hardly brake at all and only start stopping when the pedal is to the floor? The car sat for a while, is it possible I need to bleed the brakes? how about a hole in the booster?
Sometimes the light stays on.. but I'll add fluid, alot of fluid and it will be fine. Then the next day it will do the same thing. I think I have a leak in the system somewhere. The booster and below are damp, so I think I have a crap booster.
look under your dash.... right about the break pedal you will see the mechanism that operates the master cylinder.
you may have to pull some of the firewall padding back and thats a sport that the master cylinder leaks from. if so get rid of it.
Im 99% sure it's the booster. Not a big deal, i picked up the booster/master cyl assembly off the internet since i planned on gutting the entire brake system anyway.
How hard is a new booster to put on?
easy, I put one in 2 BMW's and those are BUGGARS, boosters are easy fixes . . . usually if your booster is out the pedal effort is harder, but okay!
if you're losing fluid, it's not because of the booster, remember, there is NO WATER in brake fluid so it will NOT evaporate, if it's going down it's time to replace something.
-Stig
-Stig
chitodsr
01-05-2008 01:34 PM
95SILVIA14
04-02-2005 03:36 PM
craigkiel
06-01-2004 09:48 PM
s240r
02-03-2004 04:02 PM
Matt_240
11-04-2002 07:22 PM
