frame rust?
frame rust?
I wasnt too sure where to post this but , the 240 im looking at buying has a few lil places where the frame is rusted through, i think i can weld in new peices of steel and fix this but i was just curiuse if somone could post pictures of an under carage so i can look and decide what i need to do, becuase i dont have the car in my posession. Should i fix it or just move on from this?? The car is only 200 bucks with a running KA so i figure i cant be out a whole lot but I was just looking for some insite
is rusted all the way through? or is it just some surface rust. make sure, cause if its all the way through thats a crap load of rust to go through that thick of metal. if its surface rust just take a grinder and/or steal brush and go at it. then re-coat with some undercarriage paint.
oh you said frame. floor boards not part of frame. if you can weld get it. if you cant you might want to toss the idea of getting it. if its as rusty as you say it might be a lot of body work. as for the frame if its rusted through personally i would cut out the rust and weld new steal in its place.
kable
11-19-2007 01:02 AM
somedrummer41
09-03-2007 03:35 AM
