Excessive Negative Camber
I got an alignment check done today. Turns out my front camber
is as follows:
Front: -3.7° [LEFT]-----[ ]-----[RIGHT] Front: -4.6°
technician said that he could go 1.5° MAYBE 2° positive making it
at -2.7°-ish , if I purchased their in house camber kit for
addition $100, plus $75 for alignment. This was done at
JUST TIRES.
vehicle: S14
setup: Cusco Comp-S Damper, bought it used with Upper Pillow
ball mounts. Any idea(s) in getting camber to those numbers w/o
camber kit, or should I go back and do it all for $175 plus tax?
(which by the way tech was honest enough in saying for almost
1° difference not worth it!)
is as follows:
JUST TIRES.
vehicle: S14
wow somebody should fire that tech he is the dumb
does your car have frame damage?
My front camber setting is 3.1 good setting
wtf camber kit for the front, thats what adjustable mounts are for
if you buy that kit i will beat you with a stick!
No if they are adjustable pillow ball mounts then yes.
Just because they are pillow ball doesnt mean that they are adjustable.
I just said that btw.
The Performance shop that installed the damper system said they positioned the front struts to be equally matched to one another in terms of camber. Since this item was sold to me used no spanner wrenches or such, are the top front camber mounts adjustable with a hex-shaped allen wrench of some sort, if so while on ground or lifted up? My first damper system so please excuse the tyro-ish display BTW no frame damage what so ever
damper system haha very technical.
Yes the top here
is camber adjustable by changing positions of the allen bolts. easier to adjust in the air.
Spanner wrenches just allow for height adjustment.
Good luck.
Yes the top here
Good luck.
jspaeth
04-02-2006 11:01 PM
