drive belt
first if you have the mechanical fan etc this is what you must do
1 remove fan shroud
2 remove fan using 10mm wrench. the nuts are located on the rear of the fan.
3 loosen tension on power steering pump to remove belt. for that you will need 14mm and 12mm socket or wrench
luckly that belt is the first one... you should really consult an haynes manual for visual, very straight forward bro
1 remove fan shroud
s14Drifter
09-28-2008 12:17 PM
