doing suspension upgrade
Old 10-20-2005 | 02:28 AM
Monkey Boy's Avatar
coilovers, tension rod, ruca, toe link, forward link, inner and outer tie rod ends, tie rod boot is what i am changing just thinking about anything else that will stay under 4-500 that i can add to the list before i do it. i was thinking subframe bushings, nismo rack bushings, and nismo power brace. was thinking sway bars but that can be put off for another time.
thinking about other things that could be changed out while all of that is being replaced. if any suggestions that i didn't list please let me know.
also on another note a part of my subframe got slightly bent. the mechanic jacked up my car and it and didn't center it under the bushings, it was off so it bent up the plate. if you are looking at your rear tire its the part front side of the car of the rear tire, it's a place where you would put the subframe bushings, it has a small bar bolted down to the body coming from that. http://www.driftfactory.com/memb.php it's the first picture. that got bent up on the right side of the bushing in the picture. just wondering if that can be straightened out?
Old 10-20-2005 | 02:03 PM
Levi SPL S14's Avatar
its bent dont worry its not important. use the rest of the money to get some track time.
Old 10-20-2005 | 02:54 PM
Monkey Boy's Avatar
well my suspension is pretty busted, it being a 91, and i'd like to take care of that first instead of rolling all over the place with my loose suspension.
Old 10-21-2005 | 12:36 PM
all you need is 2 way lsd, good set of coilovers and a bucket seat then go have fun.
Old 10-25-2005 | 04:17 AM
sw20>>s14's Avatar
all that at once seems too hasty...learning curve = der, have you seen my baseball?...
diego1103
20
09-26-2006 01:03 PM
Heely
25
03-17-2005 12:58 AM
beefcake6681
05-30-2003 09:26 AM
CoolCage
10-21-2002 05:54 PM
leiferik1
07-15-2002 07:26 PM
