different brake pad material?
I just ordered some cross drilled and slotted rotors and i want to put new brake pads on when I install the rotors. What i wanna know what is the difference between semi-metallic, ceramic, and organic???? What is the best??
www.google.com
do some research
what kind of driving are you doing?
you are vauge learn to ask better questions an dyou will get the answer the first time
do some research
The problem with that line of thinking is if you go too high performance, you'll end up chewing your rotors. If you put racing pads on your street car you'll wind up hitting someone because you'll rarely get them up to their operating temprature. It's extremely important to pick the right pads for your application. Just as you wouldn't go with an unsprung triple plate clutch for stop & go traffic, you don't want to go overkill in your brakes. If you're looking for a good street application, try EBC Greenstuff or anything equivelant. That would be a good application for mostly street with some racing.
