clearance
Old 04-11-2005 | 09:13 PM
nisilvia's Avatar
clearance
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA%3AIT&rd=1
Anyone knows if this would clear z32 brakes?
Old 04-12-2005 | 09:58 AM
Levi SPL S14's Avatar
hmm looks like your gonna need a spacer.
Old 04-13-2005 | 07:56 AM
ninedy_to_koop's Avatar
nope...it's not gonna go in. The wheels you're buying a 4 lugs and z32 are five lug. i think it's going to be pretty hard don't you think. or i might be wrong, but i'm 90% sure.
Old 04-13-2005 | 10:34 AM
CowboyTurbo's Avatar
you don't need 5 lug to put on z32 brakes. You will need the clearance and re-drilled rotors though. (if you plan on keeping the 4 lug setup that is...)
Old 04-13-2005 | 01:27 PM
You my friend are 100% wrong, Z32 brakes has nothing to do with lug's or lug pattern.
Cowboy Turbo is right.
When I test fitted the same wheel just slighty different specs i needed a 5mm spacer to clear Z brakes.
Good luck.
Old 04-13-2005 | 04:53 PM
JDMxDrift's Avatar
Bahhh hahah...
JDMxDrift
02-24-2005 12:43 PM
Tweaktac
12-18-2004 02:05 PM
AlexAtMyNismo
09-16-2004 10:49 AM
TurboEvo
21
02-22-2004 11:10 PM
Massimo
01-25-2003 05:16 PM
