Camber: Explained
Old 05-28-2005, 05:36 PM
  #31
LA_phantom_240's Avatar
torque steer maybe? idk
LA_phantom_240 is offline
Old 05-30-2005, 03:18 PM
  #32
himbo's Avatar
torque steer, that has nothing to do with it.
t/s is on fwd cars that have lots of power or little traction (or both ) and the steering wheel starts tugging either to one side or from side to side. this is when one wheel or the other gains and looses traction or, when on wheel or the other gets more power directed to it
himbo is offline
Old 05-30-2005, 04:53 PM
  #33
CowboyTurbo's Avatar
wouldn't an lsd fix that?
CowboyTurbo is offline
Old 05-30-2005, 05:14 PM
  #34
himbo's Avatar
for the most part. however, it is still limited, for example, the new acura tl still torque steers with an lsd
fwd has its limits, though, they can be very high nowadays
himbo is offline
Old 05-30-2005, 05:50 PM
  #35
Notice i said "idk"
Old 05-31-2005, 02:54 PM
  #36
Levi SPL S14's Avatar
imagine if cars were designed in such a way that they were actually supposed to roll on to just two wheels under hard cornering, we'd need tires like bike (motorcycle) tires... I'm not sure why, but I see a lot of photos fwd cars under hard cornering with two wheels off the ground...
It depends on the car thats doing that.
I have seen road race civics that under hard cornering wheels lift off because of the weight transfer. Those car have more suspension that we can dream of.
Levi SPL S14 is offline
Old 05-31-2005, 03:12 PM
  #37
himbo's Avatar
Notice i said "idk"
my bad i didnt mean to sound condescending or anything, i was just trying to preach on. i'm still in the fwd community, and i'm trying to pick up on all the s13/14 info, its soooo baffling
himbo is offline
Old 05-31-2005, 03:43 PM
  #38
yeah until my 240 gets plates, im stuck in my acura legend. Its not ALL bad though, its got a 5 speed, 2 doors and 170 horses and a 2.7L v-6.
Old 05-31-2005, 03:48 PM
  #39
himbo's Avatar
nice, thats posh and rare (5spd)
himbo is offline
Old 05-31-2005, 06:08 PM
  #40
rkcarguy's Avatar
The S13 with the all the negative camber is way too much. The most I have EVER seen was on some roadracing cars, about -3 degrees, because alot of them don't have enough castor(now I'll really confuse everyone)where the wheel is straight up and down 0 camber, but gets negative camber when steering is turned(outside wheel only). Alot of show cars will have crazy camber just to make those huge wheels clear the fenders. The bad part is all these setting depend on what you do with the car and the tires that are on it.
Example: I was running hoosier auto-x tires on my solo-2 car. They are soft and kinda a round profile shape with soft sidewalls. I ran about -11/2 degree all around with these. When I changed to slicks with a more square profile design and stiffer sidewalls, I went almost 0 camber and stiffer springs. The car doesn't roll as much, and has better braking and acceleration because I don't have to run so much negative camber and I get a better contact patch. It's all about KEEPING THE TIRE FLAT ON THE GROUND as much as possible.
rkcarguy is offline
Old 05-31-2005, 08:12 PM
  #41
Yes and the leather is in mint shape! Too bad the a/c compressor is missing. I picked one up from eBay for 30 bucks. I'm gonna convert it to r-134 while its all empty
Old 05-31-2005, 08:54 PM
  #42
Fast1One's Avatar
Whats r-134?
Fast1One is offline
Old 06-01-2005, 01:20 AM
  #43
castor is way overrated.
Old 06-01-2005, 06:36 AM
  #44
Originally posted by Fast1One
Whats r-134?
R-134 is the newer refrigerant. They stopped using r-12 in like '97. So now you either have to have a special license to buy r-12 or you convert to r-134.
Old 06-01-2005, 03:19 PM
  #45
Why is that? don't fwd and rwd cars take pretty much the same line going around a turn? Is there a particular reason fwd cars have wheel lift under heavy weight transfer?
Quick Reply: Camber: Explained
