broken bolt inside frame
Old 12-30-2006 | 06:38 PM
crazydrifter's Avatar
ok i love to drift but i got some stock suspension so you can see the problem already. while riding one day i heard a wierd bumping noise coming from the left front tire so i get out to check and the sway bar is hanging and the U-bolt that holds it to the frame had olny one bolt in it and the U-bolt itself....well lets just say that it is not able to be used anymore. But when i felt the hole where the other bolt should be i felt the bolt itself just broken off and now i have no idea how to get it out to fix the sway bar and i really dont want to take the whole thing off.
any help would be much apprecated
Old 12-30-2006 | 08:58 PM
easy out
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Old 12-31-2006 | 11:01 AM
trevr's Avatar
Any local garage could easily pull that out for you.
Old 01-04-2007 | 05:01 PM
thank you sounds easy enough
khailon
03-05-2007 12:34 AM
socals13guy
07-18-2006 03:43 AM
Carparthookup
09-21-2005 04:26 PM
epoxy
02-28-2005 09:46 PM
nissandrift
10-06-2004 09:09 PM
