bent spindle?
Old 10-25-2004 | 03:05 AM
Peas's Avatar
bent spindle?
ive been attack by curbs at least twice now. i hit my front passenger side pretty fast and ive replaced: tie rod, control arm, tension rod and the tension rod bracket.
my car pulls to the right and before i had a negative camber, now its straighter, more positive than before.
is it really possible to bend the front spindle and knuckle?
a local shop guy here who did my alignment after replacing the bent parts listed above said that my knuckle was bent.
basically, i wanna know if the knuckle/spindle/hub assembly, if bent could cause the wheel to sit back (towards the rear of the vehicle) a little and if it would also affect the camber and cause it to pull right.
this is such an annoying ordeal, any help and opinion is greatly appreciated.
Hamsterball
07-23-2006 08:34 PM
seracer
03-24-2006 12:02 AM
lrgkevin
04-15-2005 09:36 AM
Zushi
03-08-2005 10:37 AM
SpdElemts
09-24-2004 10:53 PM
