4 to 5 lug ABS question
Old 04-26-2004 | 05:29 PM
smokie700's Avatar
I currently have an s14 4 lug with ABS. Im getting the 5 lug conversion this week. My questions are
1. Do i have to buy 5 lug rotors with ABS?
2.^ If i do this will the ABS still work?
3. What is involved in removeing the ABS system? ( i know the obvious like remove the pump but will i have to run new lines to the mastercylinder from the brakes or what)
Any help is wanted, From what i hear it is better not to have ABS what are your thoughts on my situation?
Old 04-30-2004 | 02:00 PM
ahnyoungboi's Avatar
i dont know about the rotor but...i think the abs should work if ur just swaping out ur rotors...
when u change to a 5 lug, you have to look at the hubs u are putting in, there should be a ring around the back of the hub which should look like a dogtooth gear. you need this if your going to keep ur abs. theres also sensors on your spindle which are a ***** to take out, if ur gonna get rid or ur abs.
when i did my 5 lug conv. i got the hubs w/ abs, didn't know this until i took off my 4 lug hub and saw the ring. i also broke one of my abs sensors trying to take it off the hub.
i think abs is must if you have JUST the front calipers, mine kept locking up during my canyon runs. Once u do the Rear conv. O MAN~ what a difference, i like it just for the fact that i can predict when it will lock up, doesn't lock up unless i Slam on them....
well ABS causes understeer so thats the only downside, but you stop faster......
i found this out when exiting a corner, i woulda made it if the abs didn't turn on, my pass fander has a mark from the gaurdrail...battlescars......
Old 05-22-2004 | 07:33 PM
smokie700's Avatar
ttt
Old 05-30-2004 | 06:12 PM
smokie700's Avatar
bump for an answer to question #3
Old 06-07-2004 | 01:15 PM
areitu's Avatar
What did the five lugs say to the four?
Sa-LAP!!
Old 06-07-2004 | 04:01 PM
smokie700's Avatar
I guess that was funny. Post in 10 minutes to remind me to laugh
b0rdin4life
02-15-2006 03:33 AM
hatecivics
28
06-01-2005 08:30 PM
rb240sx
07-28-2004 05:47 PM
jdmsoarer
07-10-2004 10:58 AM
jdmsoarer
12-07-2003 06:51 PM
