No Spark????
Old 04-02-2007 | 11:54 AM
homesliceisj's Avatar
No Spark????
So we jus recently had the SR motor out of the car and did a few upgrades... Everything goes great and the car starts and run awesome. few ays later i go to start and it would jus crank and crank but not start... Fuel is fin but not a lick of spark??? Whats goin on here?
Old 04-02-2007 | 02:38 PM
check the coilpacks to make sure they are getting proper voltage, have u tried jumping it? maybe its the battery..
Old 04-02-2007 | 03:13 PM
well the car cranks fine and yes i have jumped it... how much voltage should be going to the coil packs? and what else could be the problem
Old 04-03-2007 | 01:30 PM
and how much voltage should the coilpacks be getting????
Old 04-03-2007 | 01:33 PM
Need Help Asap No Spark??
Old 04-03-2007 | 01:55 PM
just hook up the plug with the coilpack and see if the plug sparks, do so on all four.
Old 04-03-2007 | 03:43 PM
hey bro don't Triple post a topic
things you need to check:
-spark plug ( remove an single spark plug lay across valve cover and have someone crank your motor. and verify that there is no spark
( either one of these things will ruin your day)
-CAS( crank angle sensor)
-Igniter
-Connections
-grounds
check in that order, you should also run an diagnostic test, your ecu will tell you whats wrong.... unfortunately when you have a spark issue, it doesnt help if you cant get the replacement parts. remember these motors are not brand new, so don't be surprise if one of those parts fail..... give that a try and tell us what happens.
Old 04-03-2007 | 09:06 PM
That what im saying ive already takin the aprk plug out and checked it for spark I also hooked up an EFI spark test. And ther is no spark present..
Old 04-03-2007 | 09:11 PM
cool now you have to check your igniter and cas... only thing i could suggest is find a buddy who has a working cas and igniter and swap one at a time and then both and see what happens... spark issues are pretty simple to find unless something has gone very bad such as severed wire somewhere that you cant see.
Old 04-08-2007 | 12:05 PM
It was the ecu... how it got like that i dont know but it was definnetly the computer...
Old 04-08-2007 | 12:06 PM
so you just replaced it completely huh?
Old 04-08-2007 | 11:03 PM
Levi SPL S14's Avatar
Its funny how ECU's do that. They just die, i hate when that happens.
Old 04-09-2007 | 10:12 AM
Yea i replaced it... Did i have any other option??? But yea it didnt "jus go bad" the new one i bought worked for about 3 starts ups now its doin the same thing everything works except spark... What should i do about this problem insteaqd of replacing the ecu??? And what could be causeing them to go bad???
Old 04-09-2007 | 05:06 PM
man now it sounds like and electrical issue.... i would seriously trace you wiring. you could have a bad electrical load somewhere. check you battery terminals and fuses bro.. something is frying your ecu.
did you wire your car, or did some one else? if someone else, they need to check the wiring. SR wire jobs are simple to me, but they can be easily screwed up... also vibration can make wiring come loose if not done properly.
Old 04-10-2007 | 10:24 AM
I wired the car.... si ther any wireing instructions you could send me or somthing to mabey double check myself?
