Budget BPU Upgrade Guide
Old 03-02-2008 | 01:42 PM
240-kid's Avatar
So, I'm more then sure some/most of you have seen my budget threads in the KA section. If not its probably either because it wasn't stickied or because your one of those anti-KA people. But thats fine with me Well I've found myself sitting on my *** once again doing nothing but looking at parts. So I came up with this BPU budget guide for all you SR20 guys. BPU is a term the Supra guys use for, Basic Performance Upgrades. To them a BPU set-up consists of; Air filter kit/Cone filter, Turbo mani, Turbo elbow/extension, Down-pipe, and a Boost controller. But for us, I added a few things; a Small-sized FMIC, Hot-pipe, BOV, a Test-pipe & Exhaust. A stock S13 Red-top should put down around the 160-170 mark in complete stock form w/ a SMIC and maybe an wlboro only because it's a smart thing to do. All of these upgrades can get up up around the 220+ mark, depending on the condition of your motor, and what version SR20 you have. Of course the S14 will put down more power because of the T28 and NVCS, but once you replace the turbo, that will not matter as along with a new turbo comes cams and most cams eliminate the S14's NVCS. That is the reason why I'm using the S13 Red-top as the guide for the power range.
Let's start with the Intake side.
Air Filter/Intake kits: Price Range: $80 - $89
All air intakes are universal between all SR20's
HKS Direct Drive Filter: $80
Blitz LM Filter: $88
Greddy Air NX Filter: $89
Next is the FMIC, but we'll have to start with a Hot-pipe
Hot-pipes:
Both Hot-pipes posted are just the pipe, no flange for BOV are on it
Greddy Hot-Pipe: $89
S13 - S14
BOV:
Entirely upto you, you pick
When running an aftermarket BOV, I would recommend running it in re-circulation mode for when you vent to the atmosphere, the MAF has already account for that air and will flood the engine with fuel causing you to run real rich in-between shifts.
FMIC:
this FMIC is only rated to around 350 max and should not exceed that as you are going over it's cooling capacity and are just blowing hot-air into your engine and risk the cause of detonation, besides, this is only the BPU stage.
Greddy LS-Type FMIS: $425
S13 - S14
Moving oto the exhaust side:
Turbo Manifold:
Turbo manifold price range I kept under $160 so dont expect anything spectacular or HP making monsters, these are just Tubular manifolds for turbo's w/ T25/28 flanges, dont expect anything else. Also they are both bottom mount position mani's. Also these manifold's are meant for Internally WG'd (Stock-ish) turbo's. So don't even think about trying to fit that 38mm Tial WG on here
All turbo mani's posted are Universal Between all RWD SR20 Platforms.
MYSR20.com: $125
Megan Racing Manifold: $159
Turbo Elbow/Extension:
Turbo elbow/extension price range was kept under the $115 mark.
Again, they are all universal to all RWD SR20 platforms.
MYSR20.com: $90
Megan Racing: $114
Down-pipes:
Down-pipe price range was kept at the $145 mark and under.
Down-pipes are same as the Manifolds and Extensions.
XS Engineering: $99
MYSR20.com: $100
JVT w/ Flex point: $105
Megan Racing: $115
Project Silvia: $124
Titan Motorsports: $125
JIC Billet DP: $134
Greddy MX: $135
Blitz DP: $145
Test Pipes: Range From $5 -$50 on eBay
Advan-Emotion: $25
Exhaust
Now I have Found Quite a number of Exhaust Systems under $450
GP Sports EXAS Spec D: $350
S13 - S14
GP Sports G-Four D II: $440
S13 - S14
Greddy PE II: $448:
S13 Only
Apexi GT Spec: $406
S14 Only
Apexi Nior: $448
S14 Only
Buddy Club Spec II: $332
S13 - S14
Greddy Ti-C: $424 - $440
S14 - S13
HKS Hi-Power: $371 - $449
S13 & S14 Both 65mm and 85mm
Tanabe Concept G: $450
S13 - S14
Tanabe Super Medallion Racing: $418 - $443
S13 - S14
Skunk2: $430
S13 - S14 Link 1 - Link 2
Espelir JGT500: $440
S14 Only
Pit N1 Style: $370
S13 - S14
Intense Power: $295
S13 - S14
Top Speed N1: $320
S13 - S14
5Zigen Rocket 200: $415
S13 Only
Hop-Up Racing 3": $265 - 279
S13 - S14
Last but most definitely not least:
Boost controllers:
I am only posting the Electronic boost controllers.
although the MBC (Manual Boost Controllers) are much cheaper, most ppl like the bling and what not so I figured I'd post the Electronic BC's.
This is a very contorversial but I would keep boost under 10 psi, at max 12.
Price range was kept under $300
Gizzmo MBC: $225
AEM Tru BC: $269
Gizzmo I-MBC: $299
So all in all, the cheapest route possible, excluding the cost of a BOV (of your choice) the lowest total possible is: $1423
If you ask me thats not bad at all for making atleast 220WHP at minimum.
Thank you for viewing my thread.
Old 03-02-2008 | 01:43 PM
TypeX180's Avatar
nice write up dude..good stuff
i vote sticky so that people stop asking for it..maybe then they can see the ****..
240-kid
05-06-2009 05:04 PM
240-kid
SR
04-20-2008 11:35 PM
cali240sx
01-28-2007 10:11 PM
Sil80guy
02-24-2004 10:42 PM
Pro Skater
04-24-2003 01:26 PM
