Sleepy eye methods...
1. On the dash there is the headlight up/down button (not the switch on the steering column, the button to the left of the column with either the blank button or cruise control underneath it).
2. Pull that button out (may be tough at first but just tug and wiggle it, it'll come out).
3. Once it is out you will see several different color wires coming from behind the dash going to the button. There will be a brown wire.
4. Cut the brown wire.
5. Wrap the ends with electrical tape or put on the little wire cap things and your done.
reason the other one sounded funny was because I was just replying to what Hyaline said
Does anybody know of a better way, like if i shortened the headlight-to-motor linkage then repositioned the arm on the motor so the lights can go down properly and when the headlights are on then go sleepy. because i rather have that and then convert to a homemade projection light setup, so my lights still go all the way down and flip up just enough (3") to reveal the projection lights.
91coupe messing with the linkage would cause the headlights to do some funny things... but none of them would allow it to have the sleepy eye mod and close fully whenthey are off... shortening the linkage would lift the headlight when it is closed... but then it would try to force it down when it went around for the next time it was to open... i tried it and broke the little plastic brackets that hole the rod onto the headlight bucket...
hey guys i cut the brown wire today...and i manually moved the headlights to sleepy eye position but when i turn on my lights they open up again...how could i get the lights to turn on in sleepy eye position? cutting the brown wire doesnt do that?
no u got to do it they way i am goin to do it
buy puttin a toggle switch where the 5 amp fuse is in the fuse box by ur left foot in the car
put a swtich and u should be able to get sleepy eyes wit lights on
theres a write up on nissan forums
http://www.nissanforums.com/showthread.php?t=59808
#26
how do u disconnect the motors? how many screws and which screws? cuz last time i took out that screw on top of the grounding wire for the motor but when i turned on my headlights the *****es still opened up lol
#28
aight people...i've done it...look at the link that PORTION posted...thats what i did! it's a pretty tuff space to get to but it is possible..and when u get it, it's well worth it!!! it's not hard so just do it this way and stop tryin to find out different ways to do this, n HYALINE, dont disconect the motors, trust me this is easy...dont do it half way, go the whole nine yards cause its worth it! thx PORTION!
