Randy's RB20 Hatch
#96
Woo hoo! Power steering stuff is here
125 bucks for everything. dohc lines, drain line, resivoir, fitting, pump, bracket, bolts and belt. Most people can't even get the dohc lines for that much.
The car is running and driving with power steering. I'm just too lazy to take a picture.
#98
what bolts on are u running......i have minor stuff done to my rb20 including the stock rb20 turbo and my car made 268 at the wheels at 14 psi....with bigger injectors, rb25 turbo and a new intake manifold the car will make well over 300 at 15 psi
#99
interesting, i haven't seen many people do a good rb20 swap. I guess it's all in the tune.
I have a 4inch core fmic, 2.5in piping to cooler, stock crossover style intake mani, stock rb20 turbo at 11psi,,cone style filter, 3in turbo back exhaust.
Right now i have a friend setting up my wideband and emulating my ecu to clean up the fuel curve and get me ready for my injector swap.
#100
i have a huge front mount (dont kno the dimension), walboro 255, chipped ecu and other lil bolts ons.... comin this month will be.....intake manifold, 550cc injectors, 80mm throttle body, 3inch intercooler pipping, rb25 turbo, 3 inch intake pipe, a retune at 15psi so put me well over 300
#101
Im sure you will make decent power with that setup. Right now i just want the car to run right off the emulator, clean up the fuel map, that way it's ready to go for my injector swaps and such. Probably going map setup
#104
#105
Update:
Here is a few pictures of the car. The car is ultra stealth right now with it's ghetto wheels and primer paint job. Hopefully by next week ill have my wideband in and check out the stock afr's. Then as soon as my emulator comes I can start tweaking it to clean it up some. Getting ready for the turbo swap *pops knuckles*
Anyway.. Outside:
Under the hood:
Power steering! - Kinda cluttered now though :
Anyway.. Outside:
Under the hood:
