Raine's S14 Project: Keira (rawr!)
Old 12-20-2004, 02:30 AM
  #151
Mounted my gauges, sharing some pics
Hey-o... was going to update my cardomain page but cardomain site is being odd
A view from the driver's side window area.
3 gauges mounted in the dash - air/fuel, voltmeter, vacuum.
How they look at night.
Tachometer mounted to the center of the gauge cluster.
This is why I mounted a tach in front of the factory tach. When I go touge (or if my eyes hurt at night) I can dim the factory gauges and have only what's important - rpm.
Drivers view of the upper set of gauges (water temp, oil pressure, oil temp)
Better view of how they're mounted to the windshield using Greddy 52mm meter holders.
Pic of the oil pressure line and oil temp sensor mounted to the factory oil pressure switch area (so you know I'm not faking the funk)...
...and the water temp sensor installed inline with the radiator hose (would have been more accurate on the lower hose, but this works fine).
The full effect from the driver's seat. I love it! (note how my stereo and the EDFC unit snuck into the photo LOL)
If you have any questions regarding installation, post them here - I'll be glad to help out right now, so I'm posting the pics here first. Anyhow, I finally got around to installing a full set of gauges in my car... here's pics:
l2aine is offline
Old 12-20-2004, 08:29 AM
  #152
TWAN's Avatar
Wow that looks good. The first pic kind of confused me though. It looked like the gauges on the dash were reflecting on the top of the window. But the scrool down feature confirmed otherwise. Good job man.
TWAN is offline
Old 12-20-2004, 10:13 AM
  #153
C-Walk's Avatar
that looks real nice... i just wanted to know how you went about putting them in your dash? Cause i just recently bought oil pressure, water temp, volts. guages and i wanted to put them there but i cant really figure out how to go about it or where to start.
C-Walk is offline
Old 12-20-2004, 10:56 AM
  #154
badman70_1's Avatar
so much for speed accuracy between 20mph and 50mph....looks good. did you have to remove passenger side airbag?
badman70_1 is offline
Old 12-20-2004, 11:43 AM
  #155
S14Dude's Avatar
Nice job jay. Haha, driving next to you im trying to read your new guages. lol. Looks good.
S14Dude is offline
Old 12-20-2004, 12:34 PM
  #156
SR20detoofast4u's Avatar
From the looks of it, he didn't have to. The gauges are below the airbag. Correct me if I'm wrong. And Raine, your site is down...when's it gonna be up again?
SR20detoofast4u is offline
Old 12-20-2004, 12:59 PM
  #157
240sxNLR's Avatar
that is interesting, different and nice...looks great
240sxNLR is offline
Old 12-20-2004, 01:18 PM
  #158
looks damn good man
Bryan is offline
Old 12-20-2004, 02:07 PM
  #159
240-kid's Avatar
Wow never thought of mounting them up ther
What kind of gauges are those?
240-kid is offline
Old 12-20-2004, 02:09 PM
  #160
I can see what you mean by looking at the pic again LOL
If you want to put them in the dash you'd have to remove the dash from the car first before cutting anything. There's some metal plates bolted in certain sections that have to be trimmed or removed. Also, you're drilling/cutting through about 3/4" of foam/plastic. A holesaw makes the job easier, but be sure to take measurements first.
The gauges do sit below the airbag position, like sr20detoofast4u said, but they barely fit without hitting the airbag itself. The airbag has a large bracket and a weird mounting area behind that part of the dash. You also have to be careful not to get in the way of your glove box closing either. It's a tricky fit, but it's possible.
Then again, I have since removed my passenger-side airbag when I changed steering wheels so clearance wasn't a problem.
Which site? the cardomain site? I checked all of them just now, they are all working
l2aine is offline
Old 12-20-2004, 02:10 PM
  #161
Megan Racing
l2aine is offline
Old 12-20-2004, 02:14 PM
  #162
240-kid's Avatar
Wow they look great
240-kid is offline
Old 12-20-2004, 11:39 PM
  #163
you mean kmph
l2aine is offline
Old 12-21-2004, 08:38 PM
  #164
oops. yeah it was cardomain....but its up again. Man your a lucky SOB you know that? If i could actually spend money on my cat to add stuff and not "fix" things I'd be a happy person. Heh, I had to throw that in there....and yeah I forgot to say how reat they look!
Old 12-22-2004, 12:33 AM
  #165
The thing I'm proud of is that I actually bought my car, and installed everything too
l2aine is offline
Quick Reply: Raine's S14 Project: Keira (rawr!)
