my nearly complete 240 with SR20det swap!
My 1990 240 hatch
I posted sometime before that I got a motor that was knocking from JDM Engines Corp well, I bought me another one from JHOT and it works great!
I came across a good deal for the S13 front conversion, got everything for $600
JDM Engine Corp motor
Engine Picture 2
6 Months of work
Ebay FMIC 1
Suspension
Front Before Drop
Front After Drop
Rear Before Drop
Rear After Drop
Gauges
Oil Pressure 0-100 psi
Boost/Vac Gauge 0-30 psi/vac
Voltmeter Gauge
Water Temp Gauge
Water Temp Gauge 100-250 Deg. F:
Gauge Installed
Boost/Vac and Oil Pres. Gauges
Volt and Water Temp Gauges
Harness for Gauges Fans Fogs
Engine Harness
Main Harness
Power Harness
180sx Seats
Driver Seat
Passenager Seat
Both Seats
Seat Writing UpClose: NEW JUST ADDED
Ebay FMIC 2
Yes very small had new plans for it but didn't work!
Dual 12" FlexALite Fans
Koyo Radiator
Full Exhaust
Downpipe
Muffler
Exhaust Install
Engine Bay before spraypaint job:
Engine Bay 1
Engine Bay 2
Engine Bay 3
Engine Bay after Paint
Engine Bay 4
Engine Bay 5
Engine Bay 6
Engine Bay 7
Battery Tray Removed
New motor, ordered from JHOT, has just over 77xxx miles on it.
JHOT Engine 1
JHOT Engine 2
JHOT Engine 3
JHOT Engine 4
Engine Hoist
Engine Installed 1
Engine Installed 2
Engine Picture 2
6 Months of work
Ebay FMIC 1
Suspension
Front Before Drop
Front After Drop
Rear Before Drop
Rear After Drop
Gauges
Voltmeter Gauge
Water Temp Gauge
Gauge Installed
Engine Harness
Main Harness
Power Harness
180sx Seats
Driver Seat
Passenager Seat
Both Seats
Ebay FMIC 2
Koyo Radiator
Full Exhaust
Downpipe
Muffler
Exhaust Install
Engine Bay 1
Engine Bay 2
Engine Bay 3
Engine Bay 4
Engine Bay 5
Engine Bay 6
Engine Bay 7
JHOT Engine 1
JHOT Engine 2
JHOT Engine 3
JHOT Engine 4
Engine Hoist
Engine Installed 1
Engine Installed 2
The Miscellanous Parts of the car!
My Jegs Satin Finish Battery Relocation Box and Custom Mounting.
The paint job you see in the next several pictures, is gray spray paint primer!
Front Bumper:
Hood Top:
Hood Back:
Roof:
Passenger Door and Rear Fender :
Passenger Front Fender:
Rear Bumper and Lights:
Driver Front Fender:
Driver Door:
Driver Rear Fender:
Blitz intake and hks bov and hot pipe combined in single image
Wiring Harness in Dash:
A'PEXi SAFC 2:
Dash
Driver Door Interior:
Passenger Door Interior:
Silvia Gauge Cluster 180kph:
Switches Removed Except for Fog Lights Far Right Switch:
Mess in the Hatch:
Hatch Privacy Cover:
Driver Rear Interior Panel: (the only really bad eye-sore in the car! It got messed while in storage, a wall cabinet fell on it, and crushed the backside)
Passanger Rear Interior Panel:
I'm not going for all out top-end speed, or drifting, etc., yet, but more of a daily driver and every-so-often a race or two, so I'm throwing in some car audio.
Dual XDM7510 Headunit:
Dual Headunit:
Electronic motorized detachable face
Electronic volume, bass, treble, balance, fader
17x4 wRMS Peak Power
Programmable turn-on volume
Multi-button power on
1-Pair of preamp outputs
1-Pair of auxiliary inputs
iPlug Interface Cable
Black/white dot matrix type display
5 Selectable EQ curves - pop, jazz, classic, beat, rock
AM/FM/CD/MP3/WMA
Radio-30 Station Presets 18 FM/ 12 AM
MTX 81001 Amp:
Amp is:
0500 wRMS @ 4 ohm single channel
1000 wRMS @ 2 ohm single channel
1500 wRMS @ 1 ohm single channel
2000 wRMS @ 4 ohm, two amps strapped together, single channel
3000 wRMS @ 2 ohm, two amps strapped together, single channel
MTX T9512-44 Sub:
Dual 4 ohm
1000wRMS
260 oz. Magnet
9-3/4" Mounting Depth
+- 12" height
4" Voice Coil
MTX 9512-44 Sub Full Shot on Side:
Want to know how large this subwoofer is, just look at the center console panel to the right of the sub, and compare it with your console panel in your 240!!!
MTX 9512-44 Sub Cone:
NOTE: I did NOT install the sub or amp, I sold the sub, and still have the amp!
JUST ADDED:
Honestly I miss this Sub, it was a FREAKING BEAST, however I did have it installed in a box WAY to small for this sub, the box was 1.25 cu. ft. air space!!! To make this sub work suffeciently, I would need a box the size of the entire hatch area!!!
Front Bumper:
Hood Top:
Hood Back:
Roof:
Driver Door:
Driver Rear Fender:
A'PEXi SAFC 2:
Dash
Mess in the Hatch:
Dual Headunit:
AM/FM/CD/MP3/WMA
MTX 81001 Amp:
Amp is:
MTX T9512-44 Sub:
Dual 4 ohm
1000wRMS
260 oz. Magnet
+- 12" height
4" Voice Coil
JUST ADDED:
***EDIT***
All pictures were resized, sorry about the large file sizes on alot of the images, I'm not use to uploading them for people to view on the web!
Total cost of everything inbetween $8000-10,000! No Joke!
Motor that never arrived: $1500. never shipped out
Jdm Engines Corps motor: $2200. picked up
JHOT motor: $2300. shipped to dock, picked up at dock
Motors alone: $4560.
1990 240sx Hatch: $1200. bought local from friend
Intercooler #1: $242. shipped
Intercooler #2: $262. shipped
180sx seats: $500. shipped
Koyo Radiator: $335. shipped
Flex-a-Lite Fans: $270. shipped
Samco Radiator Hoses: $100. shipped
SE wheels: $100.
Springs and struts: $150. plus stock setup.
Custom wiring harness: $400.
S13 front end conversion: $600. picked up
Interior peices: $200-300.
Carpet: $100.
Wal-mart spray paint primer, Gray and black: $50. at $2.00/can
Driveshaft: $50.
Gauge Cluster Surround: $50. shipped
180kph Gauge Cluster: $90. shipped
Jegs Satin Finish Battery Box: $170. Next Day Shipping
Apex'i N1 Evo Cat-back Exhaust: $530. shipped
Enjuku Racing Hot pipe and HKS SSQV BOV combo: $340. shipped
All Radiator Hoses to make custom piping: $250.
Radio Mounting Brackets: $20. shipped (Thanks Brian)
Front CA18 Strut Bar: $40 shipped (Thanks Brian)
Rear Strut Bar: $0.00 (Stolen from Junkyard, they wanted $100. for it!)
Brake, Oil, Coolant/Anti-Freeze, ect. Fluids: $200.
Autometer Gauges and Painless Peformance Fuse Block (the wrong one): $260. Next Day Shipping
Painless Performance Fuse Block (the correct one): $110. Next Day Shipping
and much more that I can not think of!
Just got to work out some minor problems before it hits the road, the brakes bleed, and the EGR valve pipe to the dump pipe hits the steering column, and both tags need to be renewed get car painted!
SE wheels: $100.
Carpet: $100.
Driveshaft: $50.
Its been a very freaking long time since I was last on here!!!
Since then I've worked on my car quite a bit more, its running perfectly, legal with tags (funny story about inspection!) and I'm driving it! YEAH
Anyways I got a few things to update!
1) I re-uploaded all my pictures back to my site, took them down for awhile! so all pictures work again!
2)still have a crappy spray paint job, at least its not primer gray, its black!
3) My inspection went off with hardly no problems. It over heated, but a few minutes of cooling it was good again, and also the TPS was set wrong.
OK now a short story...
Getting my car inspected, the guy inspecting it popped the hood, and eyed it, He looked for a place to put the sparkplug thing or whatever it is. I told him that it is a custom motor, and that I use coil-over-plug ignition system. He got inside and after about 10 minutes of moving a sensor or something around the inside, he finally started to inspect the car.
Had a few minor problems, TPS was messed up, so rpm's was up and down, anyways, 20-30 minutes later, he said that he was done, and waiting for the pass or fail window to come up. After a long eternal 30 seconds, a note poped up saying that the motor passed! The inspection guy couldn't believe the motor passed. I nearly had a heart attack!!! I was smiling ear from ear.
Yes passed, we did not do anything to the timing or anything, it passed by itself!
Oh by the way, right after the inspection was done with, it started pouring rain!
ok now to the updates that are more current!
Picture of my Right Wheel and Side:
Yeah I know its dirty, it had rained the night before!
180sx Seats installed with Auto Power 4 point Race Harness:
Relocated Optima Yellow Top Battery in Hatch:
note: the small red wire is power for my gauges, not my entire car!
Yes I know its a getto rigged install, but I couldn't get my battery box to fit, so I had to do that temporary.
Engine 1:
Engine 2:
Front End with my Greddy M-Spec FMIC:
I know its crooked, the cold pipe was modified and cut 1" to far!
Its my nice coolant leak, Rear heater hose on motor side!
Front Right Wheel and Tire Shot:
Rear Right Wheel and Tire Shot:
Wheels and Tire Info:
Wheels: Sportmax 962 Gold w/ polished lip F:18x8.5" R: 18x9.5"
Tires: Nankang F: 225/40R18 R: 255/35R18
Tein Tie Rods and Ends and Moog R&P Bellows:
Still to be installed
Safety 21 4 Point Roll Cage:
Weighs about 20-25 pounds, its super light weight, 1-1/2" tubing
Circuit Sports Mini Oil Catch Can:
Thats it for now for the updated progress, I'm going to be ordering parts like crazy in the next week or two, so I can get my car painted, in about 3 weeks.
I'm pulling the motor, everything in the engine bay, all the interior, the dash the seats, the hatch stuff, EVERYTHING, getting the windows removed, and then get the car painted, then get my new windows, get the put in, and install everything.
Not for sure how much HP I have, but I'm going to say anywhere between 225-235hp, I havn't dyno'ed it yet, I'm doing it after I get a paint Job and car back on the road.
Completed Mod list as the car sits now...
SR20DET Motor
Greddy M-Spec FMIC
Koyo radiator
Flex-A-Lite Dual 12" Fans
Blitz SUS Power Intake
Silvia S13 Front End w/ Triple Projectors
Apex'i Evo N1 Cat-back Exhaust
Apex'i SAFC-II
RS-R Downpipe
1997 180sx Front Seats
HKS SSQV BOV
HKS EIDS
180sx 180kph gauge cluster
Optima Yellow Top Battery, Relocated in Hatch
SPEC Stage 3 Clutch and Pressure Plate
Autometer Boost/Vac, Oil Pres., Voltmeter, and Water Temp Gauges
Tanabe Front and Rear Strut Bars
Sportmax 962 Wheels 18" F:8.5" R:9.5" Gold w/ Polished Lips
Nankang Tires F:225/40R18 R:255/35R18
Samco Sport Radiator Hoses
Auto Power 4 Point Seat Harness
Eibach Sportline Springs Drop: F:2.2" R:2.1"
KYB AGX Struts
Safety 21 4 Point Roll Bar
I'll keep this updated more often. I've been busy as crap last few months to be able to get the car this far!
Engine 1:
Engine 2:
SR20DET Motor
Greddy M-Spec FMIC
Koyo radiator
Apex'i SAFC-II
RS-R Downpipe
HKS SSQV BOV
HKS EIDS
KYB AGX Struts
yeah, sorry about the I'm used to using links instead of the making the page load slower for the dial up users!
I'm resizing the images right now, it will take awhile to finish!
Update...
Finished resizing images, I lost the old resized ones, so I had to use them, and noticed that they were gigantic!!!
Yeah, I guess thats it!
Update...
