Might be getting Tein s springs, anyone want in?
#31
Originally posted by redpotatoes
Good informations. This should be sticky.
I actually have KYB GR2 with OEM springs. You mentionned:
Eibach Sportline ... at minimum you can run with KYB GR-2's ...
Eibach Prokit ... you must use aftermarket shocks like KYB AGX / Tokico Illumina / Koni Sports (Yellows) to use these correctly ...
So Prokit would not be recommended with GR2 ? Just looking to have to best springs possible for my actual GR2. Thx
IMO if you absolutely have to use Prokits with GR-2's, then it's possible but don't expect the GR-2's to last... the GR-2 was designed as an OEM upgrade - not a full blown performance upgrade. Most aftermarket springs don't go that much higher on spring rating compared to OEM so GR-2's can handle your typical S-Tech.
To be honest, if you're looking for the best spring to match your GR-2, IMO you're basing your performance spring selection on a shock that wasn't really designed as a "performance part".
#32
Thx, since I only installed GR2 at the back for inspection when I brought the car in the country, it's possible that I change the suspension to the 4 wheels next spring. I will take note of this and I will put this on hold. Thx for the info's.
S14Dude
04-23-2005 01:41 PM
