hid conversion housings
there are silvania reflector based hid housings, good pattern decentn output but you loose the high beam function. best way to do it is to retrofit bixenon hid projectors. plenty of people have done it in the diamond clear ebay housings on www.hidplanet.com I'm sure i have mentioned or posted pics of an example in another thread. search for "hid" in this forum
ill do the searching for you. look here...
http://www.club240.com/forums/showth...threadid=33930
silviaks2nr is pretty much all knowing when it comes to lighting. just read all the way through that post and a lot of your questions will be answered.
you can pm me if you have any specific questions.
if you go the projector retrofit route expect your cost to be between $200 and $500 depending on what projectors, ballasts, or bulbs you use. It CAN be done for free if you ask around at car dealers and bodyshops. sometimes you get teh free hookup
silviaks2nr
11-08-2006 01:25 PM
Evilution
05-26-2006 11:33 AM
punwannabe
09-25-2002 07:22 PM
