Headlights & HID for 95 240sx
Old 07-09-2006 | 03:39 PM
Jayson's Avatar
I like to know where I can find aftermarket headlights and HID for my 1995 Nissan 240sx.
Thank you
Old 07-09-2006 | 06:38 PM
there is a stickied thread on zenki s14 headlight options (the only aftermarket is the fk lenses) hid you will need to retrofit in low beam hid projectors, ballasts, and bulbs. I have discussed how to do this in full detail in other posts if you would please do a quick search.
edit:
okay well i feel like being helpful
you can fit a wide variety of hid projectors in the low beam reflector area, but e46 projectors are small,cheap, and easy to mount. hidplanet.com sells brand new e46 projectors for $99 or you can find them elsewhere cheaper. you could end up with something like this: (FK lenses mind you)
here are e46 projectors with the factory fluted lenses
http://www.hidplanet.com/forums/view...ighlight=240sx[/url]
basically you want to mount the projectors inside the low beam reflector. i know this is not a zenki reflector but it gives you and idea how to mount projectors in a reflector housing while maintaining adjustability:
Old 07-09-2006 | 08:36 PM
Jayson's Avatar
Silviaks2nr, thanks for the tip. I will go to that website and check it out. I'll let you know if I have other question, is that okay with you?
Old 07-09-2006 | 09:26 PM
if you can find a pair of busted hid projector headlamps you can take all the parts you need for the retrofit for under $300 probably. you can either use the oem zenki lenses, buy the fk lenses, or fab up your own out of mr10 lexan
silviaks2nr
11-08-2006 01:25 PM
socals13guy
06-27-2006 03:20 PM
JDMLyfeStyle
12-19-2005 07:08 PM
deloesian
12-27-2004 09:39 PM
bnaley
07-21-2004 11:27 AM
