energy0uth's '89 s13
Installed my Megan RUCAs. Took little longer than needed since I didn't have proper tools and tried to improvise. Eventually my buddy got everything and came over. I didn't have time to adjust them so right now its back to stock but I will adjust them to fix my camber shortly. I also got to put my wheels back on the rear and painted my roof black also. I'll update everything shortly.
Tools Needed/Helpful:
-Impact socket
-Impact gun
-19mm wrench
-17mm wrench
-12mm wrench (remove coilovers)
-Jack
-Jack stands
-PB Blaster (break the 20 year old bolts)
-WD40 (lube bolts, etc. for easy install)
Where I work...
Take off the wheels to get to the goodies
Remove front bolt on arm
Remove rear bolt on arm
Coilover removed to get out arm
Stock arm
New Megan Racing RUCA
Installed and adjusted to stock
Buddy JT came over to help and chill & then we hit Double T..."I'm Joe's bumper."
-Impact socket
-Impact gun
-19mm wrench
-17mm wrench
-Jack
-Jack stands
Where I work...
Stock arm
You and I have the exact same suspension setup. Stance coilovers and Megan RUCAs. By the way, you don't need to completley remove the coilover to get the stock arms out, there is enough give to get them out with the coils in place.
and yea I wasn't sure if they were going to make it or not and it was a lot easier with them out cuz those bolts were PITA!
Pics of the roof being painted...
Socializing w/ my buddy Justin's MKIII lol
Before
Me
Prepping & Primer (My first time)
Started painting (Gun was a little dirty and cheapy but did the job well enough for me)
After
Before
Me
After
yea I think it really sets it off and feel like they should come stock like that.
naw wasn't concerned about clear...advance has ****ty clear but the paint is decent and I like the flat look and I kept the pignose for drifting I personally like my new bumper better
#26
yeah i usually buy my paint from car quest paint stores...
it looks good for you first time, when it comes to clear coat you want a good one so they last instead of flaking off and fading. keep up the good work
#28
ive always wanted to do the red with black roof paint job, but my car is black so there is a lot of red to paint unlike the cars that are red and only have to paint the top...LOL...im too lazy and cheap right now....besides im too busy prepin for deployment
