300ZX Brakes.....finally! (w/pix)
Brembo Slotted Vented Rotors (Front Pair) $195.00
300zx SS custom Front brake line conversion $53.00
Z32 Calipers (30mm iron calipers) $63.86
Z32 Caliper Hardware $70.00
Z32 EBC Greenstuff Pads $60.00
Machine Shop ReDrill $100.00
total ~ $550
If i could have done it again. I would have bought KVR Z32 rotors from PDM. Would have saved $40......also, no one tells you that plain calipers DO NOT come with pad pins, pad pin clips, spring clips, plus i bought a Z32 master cylinder reservior and cap that i didn't end up using.
total ~ $550
how do i post pictures w/o them being an attachment (ie) where the picture actually appears in the thread w/o having to be uploaded? also, if i do it this way, am i still limited to 204kb?
and.....how do i add multiple cars in my avatar section?
nice... im not to fond of the gold calipers. but thats just m. on your car they look awesome. i know you probably painted that color. all in all a solid 10
use upgraded supra brakes with the 300zx calipers with the mckennie(??spelling??) motorsports custom brackets.. it was in one of the magazines on a project silvia
don't think i'll do the rear. the pedal feel is great with the current setup.
300ZX front 30mm calipers/11" rotors.
stock setup in rear.
i was gonna originally change the master cylinder to 300ZX, but bolted on the calipers first and went for a drive. it felt ok, so i returned the master cylinder. i'll probably save the money for the next upgrade........carbon fiber hood to replace that heavy-*** hood. but i think i will paint the rear to match the front.....duplicolor vht paint........trying to emulate the 350Z brembo brakes.....don't know if anybody noticed, but i did shave off the "Nissan" lettering off of the caliper, this was so my rims would clear(40mm offset).....didn't want to use a spacer.
Brakes look good too man
better shot of wheel/brake combo.......can you tell i've got busted t/c rod bushings.......just like everyone else.
thanks for the comments.....now i really want to get rid of these 215/40/17 tires and get 225/45/17s.......i think that will get rid of the wheel gap.
You know, with a spring and strut loweirng kit, you can cut the spring, and your ride will still be stiff. Cutting a lowering kit is not like cutting stock srpings. Them metal on a lowering kit is much more dnese, so cutting your existing lowering kit will get rid of your fender gap, and you will still have a stiff ride (note whenever you change ride height, you risk your struts going bad) looks good.
Now this is a stupid question, but z32 is a model of 300zx right? I mean when you say z32 calipers, you mean calipers off a z32 300zx right? So the only thing you need to buy aftermarket that does not come stock on the 300zx already is a brake line conversion?
i'm definitely not cutting the Eibachs.....i figure they spend alot of money in R&D, so i'd better not mess w/that. i've seen another setup like mine Eibach sportlines/KYB running 225/45/17 and it looks much better....so, i may just get the rear tires for now, or better yet. leave it be......i just bought a turbo kit for my integra, so that's where my money is gonna go for the next few months. i'm having to share funds between the two cars.
As far as i know, Z32 is the body code for the 90-96 300ZX, just like integras are DC2, DC4, DC5, etc.....silvia aka S13......anyone feel free to correct me if i'm wrong.......and yes, the brake line is the only part that is not on a 300ZX.
