LSD- J30 or aftermarket???
Old 02-26-2004, 04:39 PM
mr_synister's Avatar
I'm looking for an LSD for drifting purposes......duh. The prices of aftermarket LSD's are crazy. I can get a infiniti J30 to fit for about 250 bucks, less than a 3rd of the cheapest aftermarket one. I'm just worried that it may not be good enough. I'm considering the fact that a j30 would have probably been babied since you don't really see that many Infiniti drifters . But will it have enough torque to push me through the turns? I know that it won't last forever and it won't be as strong as an aftermarket one. But will it be good enough? Anyone tried it??? Thanx
mr_synister is offline
Old 02-26-2004, 06:46 PM
It should be enough for your purpose...but im sure you will upgrade later on down the road to a clutch type LSD right?
-HyJynX- is offline
Old 02-28-2004, 09:51 PM
focalguy's Avatar
250 now, $1k later, or $1k now?
Depends how bad you want it. Do some searches on the differences and side for yourself. I paid $900 for my 2way clutch lsd and I love it!
focalguy is offline
Old 03-04-2004, 02:58 PM
Crap, I didn't know that J30 was viscous. Getting it would be a waste. I'll just have to save up for a aftermarket one. Anyone know of good cheap ones? That was an oxymoron wasn't it?
Old 03-04-2004, 05:22 PM
Yea, good and cheap dont go together at all. Kaaz will probably be the cheapest...
-HyJynX- is offline
Old 03-06-2004, 10:34 PM
focalguy's Avatar
I've had my Kaaz for about 6-8k miles and I love it! It was about the cheapest, but most of the 2way were around the same price.
focalguy is offline
Old 03-08-2004, 08:24 PM
boricuajr's Avatar
buy a z32 non turbo lsd, take out the guts and put it in the S13
boricuajr is offline
Old 03-09-2004, 04:01 PM
I'm pretty sure that's viscous. To my understanding all Nissan OEM LSDs are viscous, until the S15. So aftermarket is the way to go.
Old 03-12-2004, 02:45 PM
Z-bra's Avatar
what is a viscous??
Z-bra is offline
Old 03-12-2004, 04:14 PM
http://auto.howstuffworks.com/differential7.htm
Search buddy...
-HyJynX- is offline
Old 03-12-2004, 04:24 PM
Catharsis's Avatar
dont waste your time with a vlsd you wil burn it out if your drifting much
Catharsis is offline
Old 03-16-2004, 09:27 PM
stannyboy's Avatar
I say go with an aftermarket.. not worth spending the money on a vlsd unless your worried about noise.. I have a kaaz 2 way and its awsome.
stannyboy is offline
Old 03-23-2004, 08:17 AM
Bahraini240sx's Avatar
I have fixed a Z32 n/a on my 92' SX and when I tested it after that I discovered it's an open diff I was very dissapointed!! Can I fix that?? I mean, can it bee having some broken components?? coz from what I understood, the 300zx n/a has an LSD!!
Bahraini240sx is offline
Old 03-24-2004, 07:56 AM
ZenkiSE's Avatar
Location: You know the dirty south...I live in the clean spot
Bahraini 240sx there is a kit from KAAZ i believe that turns an open to a 2 way i think someone help me out if im wrong. I have a J30 diff and i drift somewhat regularly and i have never had any problems with it i changed the diff oil out with royal purple and will plan on changing it out every year BUT i do see your point with the 2 way LSD and i believe KAAZ is the cheapest so if you are learning to drift i would get the J30 and then save up and then get a 2way LSD ...BUT thats my opinion
ZenkiSE is offline
Old 03-24-2004, 09:32 PM
drew935's Avatar
I do have some of those locking things to make a open diff into a closed closed. Can't remember the name right now and I'm not sure if it works in FWD and RWD... I'll check if want me to. I know that it doesn't wear out and it isn't hard to do in a pumkin compared to a FWD tranny.
drew935 is offline
Quick Reply: LSD- J30 or aftermarket???
