Hooking up safc 2?
goto www.apexi.com and look for the wiring diagram
This following is the guide for the connecting the Apexi SAFC II to your cars' ECU based on non-KARMANN sensor:
Wire from SAFC II:
Red - Power
Green - RPM
Purple - Knock Sensor
Grey - Throttle Position Sensor (TPS)
Brown - Ground
Black - Ground
Yellow - MAF output
White - MAF input
1993 240sx speed sensor at ecu: yellow/green wire (32)
ka24e/ka24de ecu:
Power – black white
Rpm – yellow/red stripe
Knock – none
Throttle – white
Ground – black
MAF(air flow) – white
sr20det ecu:
Power – black/white (47)
Rpm – red/white (8)
Knock – white (27)
Throttle – white (20)
Ground – black (17)
MAF(air flow) – white (16)
here is a link to the ecu pin outs:
http://datnet.org/cgi-bin/clickcount...nfo/page1.html
Wire from SAFC II:
Red - Power
Green - RPM
Brown - Ground
Black - Ground
Yellow - MAF output
White - MAF input
ka24e/ka24de ecu:
Power – black white
Knock – none
Throttle – white
Ground – black
sr20det ecu:
Rpm – red/white (8)
Knock – white (27)
Ground – black (17)
