engine swap help yo!!!!
Old 11-12-2010 | 08:32 PM
justgotta240's Avatar
pretty much tomorrow we are gonna get a new engine for my friend now this guy said it might have a "timing issue" and were both not really sure if there even is a problem with it. due to this guy had like 4 240sx and one had a timing issue, now is there an easy way to check if the crank is lined up with the cams right or even an easy way to check it
and if not is there and easy way to put the crank a tdc and then line the cams up acording
i have looked on google and a couple other forums and we dont know how to check without dissasembling half of the engine
Old 11-12-2010 | 11:08 PM
leak down test will work, and you wont need to take anything apart.
Old 11-16-2010 | 10:07 AM
i know what a leak down test is but my friend doesnt haha jpjp
how would i do that?
and one random *** question what is that little spring under the shifter in the tranny
Old 11-16-2010 | 11:50 AM
zenkizen
10-11-2005 11:06 AM
TorqueFreak240
10-10-2005 12:53 AM
pakidrifter
02-04-2005 12:58 PM
SilviaJai
09-23-2003 08:36 AM
encasemyheart
09-06-2002 03:20 AM
