DIY coilovers
Re: camber plates and control
Originally posted by Sieji
I'm thinking about some rs-r's and some AGX stiffs... thx all for the helpful spats of experience. Question: the rs-r's i'm planning to get only drop the car bout an 1" to 1.4", do I really need the pillows or control arms. I know slamming the car throws the camber off and makes rubber sushi of ur tires, but near an inch wouldn't hurt would it?... anyone with this setup, comment?
PS: I drive hard (previous 4x4 owner/went mudding alot) and I love rain and snow... best times to practive oversteer)
sieji
sieji
Artic has a good point (which I overlooked somehow) - Sieji, if you go with RSR ti2000 or Down Springs (both around 160-210 lbs./inch), they will work fine with KYB AGX's.
However, you won't match up the shock and spring properly if you go for the RSR Race Spring, which is significantly stiffer at 279 lbs.\inch up front, 194-251 lbs.\inch in the rear. RS-R Race Springs are better matched with Koni's (which I've ran before in my car).
This is why a common recommendation around here is the Tein S-Tech's (180-210 lbs/inch) on KYB AGX shocks. Together you can't bat this combo in the "bang for the buck" category.
BTW for the benefit of others, all the lbs/inch ratings I listed are within range for both S13 and S14; check respective manufacturer sites for the specific #
aurora61
08-28-2006 08:39 PM
U_NeeKz
02-22-2004 11:28 PM
