best high oerformance exhaust
Old 01-19-2005 | 11:21 AM
  #46
Jack The GTR's Avatar
oops sorry i did what i commonly use to do,confused your car with brandons! haha sorry. so howd the story go about the whole ticket thing? care to tell us?
Old 01-19-2005 | 12:48 PM
  #47
no, you confused his car with mine, There's a BIG difference. Don't get me started.
As for the ticket, when it's done I'll tell you what happened... I have a final court date on the 30th of March
Old 01-19-2005 | 04:53 PM
  #48
BigVinnie's Avatar
Originally posted by KAsingleC
My 89 came withpacesetter (not sure what series) not installed just flopping around in the hatch and when I installed them my stering column that runs next the the header would make contact with the header under load like exiting a turn or just revving due to the engine rocking and would lock up my steering for a second
I think you have more of a engine mount problem, sounds as if the left mount needs replacement, it also sounds like it is a pacesetter header that was installed. You may also want to change out your transmission mounting bracket bushings, it seems that they are worn as well. If you do change them install the polypropelien bushings they are mega strong compared to the OEM rubber.
If the install allows it to fit with out any fabing, it is defenitely a engine mounting problem.
You may also want to check the serial NO. You may have the 95-98 pacesetter header, there are clearance issue's between the s13 and s14 KA24de pacesetter headers.
After doing further research. I am going to purchase the pacesetter exhaust system. For the price it will give me the added performance I need, it isn't to much louder than oem, I get a 1/4" more of exhaust pipe, and I can have it for under $220.00 total on ebay.
When the exhaust system goes in next month I am going to run straight 21/4" pipe where the catalytic goes. That way only at smog testing I will reinstall it. HAHA a cooler running engine with an extra 10donkey's at the wheels Kick A#%.
Pig Fuc#$ers will mostly pull people over and site a ticket if they can prove you have an exhaust with no muffler. To the "law's" concern if you have a muffler that runs straight pipe through it, it is not considered a muffler. Little ***** piggy's do this stupid visual test where they put a flashlight to look as far down the exhaust as possible. If they can look through your muffler more than 3" from the begining of the muffler tip you will get a fatty retarded ticket.
The pacesetter exhaust system passes all the recomended visual test by the state of Cali.
Old 01-20-2005 | 03:09 PM
  #49
Darren337's Avatar
makes me wonder if some well placed layers of mesh inside the muffler can fool the cops and their visual inspection.
Old 01-20-2005 | 03:14 PM
  #50
eep dont get mad ! simple mistake. NOW they are worlds different but before externally they werent other than the wheels =( dont get mad
Old 01-20-2005 | 10:08 PM
  #51
Wow if you only knew what the two cars looked like BEFORE he bought my old suspension... anyhow -
- SE five lug baby... that's all I have to say
Old 01-30-2005 | 01:00 AM
  #52
iceman4's Avatar
so did we come to any consensis here? RSR EX-mag, or HKS hi-performance seem to be the top? is that correct?
Old 01-30-2005 | 01:36 AM
  #53
BigVinnie's Avatar
As long as you are still using a stock oem catalitic converter, there is no top of the line anything when it comes to exhaust. Until I see dyno charts I will stick with "The BOO BOO" pacesetter 21/4 exhaust.
Old 01-30-2005 | 04:43 PM
  #54
unless you go same size piping all the way forward from the muffler to the header (not to mention an aftermarket header, intake, etc.) you won't be getting "maximum flow" but you could have "maximum noise" which might not be a good thing if you live in retarded places i.e. California
Old 01-30-2005 | 05:46 PM
  #55
BigVinnie's Avatar
:you could have "maximum noise" which might not be a good thing if you live in retarded places i.e. California
F@$k Barbara Boxer the ***** needs to die a slow horrible death!
Old 01-31-2005 | 06:10 PM
  #56
iceman4's Avatar
so im buying headers and a full exhaust system, what do i want, for both? what goes good together? not super loud, not big bugger fat exaust tip either
Old 01-31-2005 | 06:23 PM
  #57
BigVinnie's Avatar
Biggest bang for your buck. OBX exhaust header, it's cheaper than DC sports and if you don't live in Cali it will work great. Then I would pick up the random Technology (50 State street legal) high flow CAT, you can purchase it through STILLEN.com, you might be able to find it somewhere for cheaper. If you dont want to get to loud I would keep your pipe at 21/4 with the pacesetter CAT back exhaust for $220.00, or if you want to break some bread you can purchase the Greddy SP cat back exhaust 21/2 for $600.00, it is a noise compliant exhaust system for high performance.
You will get about 15HP at the wheels and with added engine mods possibly more.
Old 01-31-2005 | 08:55 PM
  #58
BigVinnie's Avatar
Remember if you ever go NOS you will probably want the Greddy SP 21/2" piping.
Old 02-04-2005 | 10:12 AM
  #59
babyboy02k's Avatar
Question
hey i just got a 91 240 hatchback 4 banga 2.4 dohc and i was wondering if it would be right to get my self apexi n1 dual 2.5 inch exhaust i want this exhaust deff butt is 2.5 piping right i wana have the right backpressure dont wana lose horse wana gain also if i go with this what intake manifold, intake,headers, should i go with what would be best for the gains not losses
Old 02-04-2005 | 12:33 PM
  #60
ArticDragon's Avatar
That size is just right for streetable NA apps, but they are loud.
Quick Reply: best high oerformance exhaust
