'For Sale' Suspension / Brakes / Wheels / Tires Includes pads, rotors, springs, shocks, swaybars, and other handling related components.
JIC Magic FLT-A1 S13
Old 04-03-2007 | 03:47 PM
201Motorsports's Avatar
We have one set in stock. These bad boys, of course, need NO introduction! Here's the specifications on them though, I can get more pretty quickly if there's a high demand
The JIC FLT-A1 is a coilover suspension set up ideal for the enthusiast that will use the suspension on a daily basis and occasionally for the track. FLT-A1 features a 10 way adjustable damper. For strength, strut-type suspensions feature a wide shaft while multi-link type suspensions feature the smaller shaft damper.
FLT-A1s include front pillow ball upper mounts and front adjustable camber plates.
Also included are springs of the linear-type for laser precision handling and adjustable lower brackets for ride height adjustments that do not affect damper travel.
The spring rate on the 240SX S13 -specific FLT-A1's is: 7kg/5kg
Adjustable Dampening
Available for all applications with 10 ways adjustability. With this feature, you are able to tune your suspension dampening up to your spec.
Adjustable Pillow Ball Uppermount
Included for all vehicles for the front and some for rear application. Adjustable camber plate also included for most vehicle front applications with Macpherson Strut suspension systems.
High Tech Twin Tube Dampers
The twin tube dampers sho the different sized shafts. because strut-type suspension require more strength for support, the wider shaft (right) is the damper of choice while the narrower shaft (left) is for multi-link / double wishbone suspension.
Height Adjustable Bracket
Adjustable height aluminum CNC machine-built bracket for double wishbone or multilink suspension.
If you need these for an S14 or if you're interested in the FLT-A2's, I can definitely get ahold of them for you!!
Normal Price: $1380 plus shipping
Sale Price: PM ME!
Old 04-27-2007 | 09:02 PM
We still have a few of both the FLT-A1 and FLT-A2!
Clements
05-02-2006 04:48 PM
240SX turbo
10-06-2005 07:28 PM
JaceDM.RPS13
03-16-2005 11:25 PM
james_s14
02-03-2005 03:08 AM
Kiro1968
06-29-2004 05:12 PM
